Salta al contenuto principale
Canon CanoScan N670U White Document Mat Replacement
Cosa ti serve
  1. Canon CanoScan N670U White Document Mat Replacement, White Document Mat: passo 1, immagine 1 di 1
    • Open up the top of your Canon CanoScan N670U to this position.
  2. Canon CanoScan N670U White Document Mat Replacement: passo 2, immagine 1 di 1
    • The document mat is taped on to these four corners of the cover. These spots will be where we'll start removing the mat.
  3. Canon CanoScan N670U White Document Mat Replacement: passo 3, immagine 1 di 1
    • Gently peel the tape on each corner of the mat using your hands or an iFixit Tech Knife.
    • Be careful to not rip the foam while peeling.
  4. Canon CanoScan N670U White Document Mat Replacement: passo 4, immagine 1 di 1
    • Tape in your replacement document mat back onto the top cover of the scanner.
Conclusione
To reassemble your device, ensure that the white document mat is firmly glued on.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 280
