Introduzione
Old, degraded light seals in the Canon AE-1 can cause light leaks, leading to ruined exposures. Use this guide to replace the light seals in your Canon AE-1 to prevent these issues and extend the life of your camera.
Cosa ti serve
Hold the camera with the back facing you, and gently pull up on the rewind knob located on the top-left side of the camera using your other hand.
Carefully open the back of the camera to reveal the film compartment.
Place the camera on a clean, stable surface to access the grooves more easily and work comfortably on removing the old seals.
Carefully close the camera back and open it again to check for any gaps or misalignment.
Ensure the camera back closes securely without resistance and that the mirror damper is properly installed.
Your Canon AE-1 Program is now ready for a test roll to ensure there are no light leaks!
Congratulations! You've successfully replaced the light seals in your Canon AE-1. Enjoy shooting with your refurbished film camera!
