Salta al contenuto principale
Campbell Hausfeld FP204800 Thumb Screw Drain Replacement
Cosa ti serve
  1. Campbell Hausfeld FP204800 Thumb Screw Drain Replacement, Remove Thumb Screw Drain: passo 1, immagine 1 di 1
    • Remove the thumb screw drain from the bottom of the compressor using a Smart Wrench.
    • The thumb screw may not easily be removed due to corrosion.
  2. Campbell Hausfeld FP204800 Thumb Screw Drain Replacement, Apply Teflon Tape: passo 2, immagine 1 di 1
    • Apply teflon tape to the replacement thumb screw drain.
    • The teflon tape should be wound tightly around the entire threaded portion of the thumb screw drain.
    • When you reassemble the thumb screw drain on the compressor, make sure to fully tighten it using a Smart Wrench.
Conclusione
Eric
Membro da: 10/09/14
409 Reputazione
3 Guide realizzate
Cal Poly, Team 14-29, Maness Fall 2014 Membro di Cal Poly, Team 14-29, Maness Fall 2014
CPSU-MANESS-F14S14G29
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 15
Tutti i Tempi: 375
