Salta al contenuto principale
Campbell Hausfeld FP204800 Safety Valve Replacement
Cosa ti serve
  1. Campbell Hausfeld FP204800 Safety Valve Replacement, Remove Safety Valve: passo 1, immagine 1 di 1
    • Using the medium crescent wrench, unscrew the safety valve by twisting it counter-clockwise.
    • The safety valve may be difficult to unscrew because of corrosion.
  2. Campbell Hausfeld FP204800 Safety Valve Replacement, Apply Teflon Tape to Safety Valve: passo 2, immagine 1 di 1
    • Apply teflon tape to the replacement safety valve.
    • The teflon tape should be wound tightly around the entire threaded portion of the safety valve.
Conclusione
Eric
Membro da: 10/09/14
409 Reputazione
3 Guide realizzate
Cal Poly, Team 14-29, Maness Fall 2014 Membro di Cal Poly, Team 14-29, Maness Fall 2014
CPSU-MANESS-F14S14G29
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 411
