Salta al contenuto principale
Campbell Hausfeld FP204800 On/Off Switch Replacement
Cosa ti serve
  1. Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove Shroud Screws: passo 1, immagine 1 di 3 Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove Shroud Screws: passo 1, immagine 2 di 3 Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove Shroud Screws: passo 1, immagine 3 di 3
    • Unscrew the four 1cm long shroud screws using a 6mm Allen Wrench.
  2. Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove Shroud: passo 2, immagine 1 di 2 Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove Shroud: passo 2, immagine 2 di 2
    • Remove the plastic shroud from the compressor.
    • Do not pull the shroud too far from the compressor. You could damage the on/off switch wiring.
  3. Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove The Wiring From the Pressure Switch to the On/Off Switch: passo 3, immagine 1 di 1
    • Gently pull the wire attached from the pressure switch to the on/off switch.
    • It should come off the pressure switch with ease.
    • Make sure you are pulling the correct wire. The pressure switch could be in a different configuration on your compressor than in the picture.
  4. Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove the On/Off Switch Wiring: passo 4, immagine 1 di 1
    • Gently pull the wire connected from the on/off switch to the motor of the compressor.
    • It should be the only wire keeping the shroud from being lifted from the compressor.
  5. Campbell Hausfeld FP204800 On/Off Switch Replacement, Configure the on/off switch for removal: passo 5, immagine 1 di 2 Campbell Hausfeld FP204800 On/Off Switch Replacement, Configure the on/off switch for removal: passo 5, immagine 2 di 2
    • Twist the On/Off switch from the underside of the shroud.
    • Twist 90 degrees in any direction or until the on/off switch prongs are in a vertical position.
    • When the switch has reached the correct position, you will feel it "click" into place.
  6. Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove the on/off switch: passo 6, immagine 1 di 1
    • Push the on/off switch from the underside of the shroud until it comes loose.
    • If the switch is not in the correct position highlighted in the previous step, it will not be easily removed and could damage the shroud.
Conclusione
Caleb Davies
Membro da: 10/07/14
528 Reputazione
4 Guide realizzate
Cal Poly, Team 14-29, Maness Fall 2014 Membro di Cal Poly, Team 14-29, Maness Fall 2014
CPSU-MANESS-F14S14G29
4 Membri
7 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,682
