Salta al contenuto principale
Cambridge SoundWorks OontZ Angle Plus Rubber Casing Replacement
Cosa ti serve
  1. Cambridge SoundWorks OontZ Angle Plus Rubber Casing Replacement, Rubber Casing: passo 1, immagine 1 di 1
    • Remove the six screw covers from the bottom of the device.
  2. Cambridge SoundWorks OontZ Angle Plus Rubber Casing Replacement: passo 2, immagine 1 di 1
    • Starting from the screw covers, remove the front and back casing of the device.
  3. Cambridge SoundWorks OontZ Angle Plus Rubber Casing Replacement: passo 3, immagine 1 di 1
    • Carefully pull off the casing covering the ends.
  4. Cambridge SoundWorks OontZ Angle Plus Rubber Casing Replacement: passo 4, immagine 1 di 1
    • Slowly remove the casing from the top of the device.
Conclusione
USF Tampa, Team 1-1, Nance Spring 2016 Membro di USF Tampa, Team 1-1, Nance Spring 2016
USFT-NANCE-S16S1G1
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 11
Tutti i Tempi: 361
