Salta al contenuto principale
CR-10S PRO Y Axis Linear Rail Kit Installation
Cosa ti serve
  1. CR-10S PRO Y Axis Linear Rail Kit Installation, Machine Prep for linear rail kit: passo 1, immagine 1 di 1
    • Remove Bed leveling knobs
    • Be careful when lifting the bed off the Y Carriage. The springs may fall when lifting the bed up.
    • Lift bed and set to the back left side of the printer
  2. CR-10S PRO Y Axis Linear Rail Kit Installation, Frame Bolts Swap: passo 2, immagine 1 di 3 CR-10S PRO Y Axis Linear Rail Kit Installation, Frame Bolts Swap: passo 2, immagine 2 di 3 CR-10S PRO Y Axis Linear Rail Kit Installation, Frame Bolts Swap: passo 2, immagine 3 di 3
    • Note: uses the stock CR10S Pro Y carriage with Vslot wheels assembly to keep the rails aligned while replacing the frame bolts
    • Remove with M5X30 SHCS one at a time
    • Replace with M5X30 BHCS
    • Slide Y carriage off from the front of the machine
  3. CR-10S PRO Y Axis Linear Rail Kit Installation, Rail Prep Instructions: passo 3, immagine 1 di 1
    • Remove from packaging
    • Note, do not touch the rail directly with your hands.
    • Wipe down rail with a lint free cloth
    • Add grease to the grease port on each side of the rail
  4. CR-10S PRO Y Axis Linear Rail Kit Installation: passo 4, immagine 1 di 3 CR-10S PRO Y Axis Linear Rail Kit Installation: passo 4, immagine 2 di 3 CR-10S PRO Y Axis Linear Rail Kit Installation: passo 4, immagine 3 di 3
    • Pre-insert Spring loaded and use an Allen wrench or screwdriver to help align
    • M3 Spring loaded T-nut
    • Use the circled Rail mounting positions
    • 16x M3x8 SHCS
    • Picture with MGN guide on rail
  5. CR-10S PRO Y Axis Linear Rail Kit Installation, Rail Adapter Plate install: passo 5, immagine 1 di 2 CR-10S PRO Y Axis Linear Rail Kit Installation, Rail Adapter Plate install: passo 5, immagine 2 di 2
    • Tighten the screws evenly in an X shape
    • 4x Adapter Plate
    • 16x M3x6 FHCS
  6. CR-10S PRO Y Axis Linear Rail Kit Installation, Stock Y carriage Plate Prep: passo 6, immagine 1 di 3 CR-10S PRO Y Axis Linear Rail Kit Installation, Stock Y carriage Plate Prep: passo 6, immagine 2 di 3 CR-10S PRO Y Axis Linear Rail Kit Installation, Stock Y carriage Plate Prep: passo 6, immagine 3 di 3
    • Remove all Vslot wheels and bolts
    • Install endstop Trigger at this location
    • Picture 2 shows endstop Trigger install
    • M5x35 SHCS
    • 3x Stock Vslot wheel spacers
    • M5 Nylon Ring Lock Nut
  7. CR-10S PRO Y Axis Linear Rail Kit Installation, Y Carriage Plate install: passo 7, immagine 1 di 3 CR-10S PRO Y Axis Linear Rail Kit Installation, Y Carriage Plate install: passo 7, immagine 2 di 3 CR-10S PRO Y Axis Linear Rail Kit Installation, Y Carriage Plate install: passo 7, immagine 3 di 3
    • Belt mounting holes goes on the right side of the priter
    • Left side screws
    • Some early kits are drilled and taped for M5 Screws. The M4x8 FHCS is substituted for a M5x10 FHCS and the M4x10 BHCS substituted for M5x10 BHCS.
    • 2x M4x8 FHCS
    • Right screw stack order
    • M4x10 BHCS - M4 washer - M4 Large OD washer
    • Tightened the left side screws first
  8. CR-10S PRO Y Axis Linear Rail Kit Installation, Belt spacer install: passo 8, immagine 1 di 3 CR-10S PRO Y Axis Linear Rail Kit Installation, Belt spacer install: passo 8, immagine 2 di 3 CR-10S PRO Y Axis Linear Rail Kit Installation, Belt spacer install: passo 8, immagine 3 di 3
    • Belt Bracket Spacer
    • 2x M4x20 SHCS
  9. CR-10S PRO Y Axis Linear Rail Kit Installation, Endstop Braket mounting hardware Change: passo 9, immagine 1 di 1
    • Remove the stock endstop bracket screw
    • Replace endstop bracket mount screw with:
    • M3x10 SHCS, M3 Washer and M3 Sliding tnut
  10. CR-10S PRO Y Axis Linear Rail Kit Installation, Rail stopper install: passo 10, immagine 1 di 2 CR-10S PRO Y Axis Linear Rail Kit Installation, Rail stopper install: passo 10, immagine 2 di 2
    • M5*10 BHCS
    • Acrylic stopper
  11. CR-10S PRO Y Axis Linear Rail Kit Installation, EndStop adjustment: passo 11, immagine 1 di 1
    • Adjust the Endstop position by sliding the endstop back until the nozzle tip lines up with the front edge of the bed when the endstop triggers.
Linea Traguardo
Altre 3 persone hanno completato questa guida.
AJ Pereira
Membro da: 05/29/20
2.735 Reputazione
16 Guide realizzate
Tiny Machines 3D Membro di Tiny Machines 3D
Community
5 Membri
41 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 91
Tutti i Tempi: 4,787
