Salta al contenuto principale
CR-10 V2 Linear Rail Kit Hotend Installation
Cosa ti serve
  1. CR-10 V2  Linear Rail Kit Hotend Installation, Hotend Removal down: passo 1, immagine 1 di 3 CR-10 V2  Linear Rail Kit Hotend Installation, Hotend Removal down: passo 1, immagine 2 di 3 CR-10 V2  Linear Rail Kit Hotend Installation, Hotend Removal down: passo 1, immagine 3 di 3
    • Remove the Hotend cover screw
    • Remove the Hotend mounting screws
  2. CR-10 V2  Linear Rail Kit Hotend Installation, Belt removal and Stock X Carriage: passo 2, immagine 1 di 3 CR-10 V2  Linear Rail Kit Hotend Installation, Belt removal and Stock X Carriage: passo 2, immagine 2 di 3 CR-10 V2  Linear Rail Kit Hotend Installation, Belt removal and Stock X Carriage: passo 2, immagine 3 di 3
    • Loosen Idler pulley bracket screws and remove the idler pulley bracket
    • Remove the belt
    • Remove the lower V-slot wheel bolt from X-carriage
  3. CR-10 V2  Linear Rail Kit Hotend Installation, Mounting screw Pattern & Sliding on the Rail: passo 3, immagine 1 di 3 CR-10 V2  Linear Rail Kit Hotend Installation, Mounting screw Pattern & Sliding on the Rail: passo 3, immagine 2 di 3 CR-10 V2  Linear Rail Kit Hotend Installation, Mounting screw Pattern & Sliding on the Rail: passo 3, immagine 3 di 3
    • Follow the table for the recommended mounting locations
    • Take note to skip 2 holes between fasteners, and make sure to mirror this process from each of the end of the rail until you meet in the middle.
    • For rails with an odd number of mounting holes, the pattern will overlap in the middle
    • For rails with an even number of mounting holes, the pattern will be continued across the rail
    • Pre-install all the M3x8 SHCS screw and Sliding T-nuts
    • Install the Printed T-nut guide on the end of the X axis extrusion, and slide the rail on to the X-axis from Right to left
    • The guide helps to slide the T-nuts into the extrusion
  4. CR-10 V2  Linear Rail Kit Hotend Installation, Mounting the Rail: passo 4, immagine 1 di 3 CR-10 V2  Linear Rail Kit Hotend Installation, Mounting the Rail: passo 4, immagine 2 di 3 CR-10 V2  Linear Rail Kit Hotend Installation, Mounting the Rail: passo 4, immagine 3 di 3
    • Slide the rail until you have about 2-3 mm between the rail and the end of the X axis extrusion.
    • Use both Linear rail Guide to center the rail to the Aluminum extrusion
    • Tighten the mounting screws as you go down. Making sure to slide down, slide the linear rail guide down as each screw is tightened.
  5. CR-10 V2  Linear Rail Kit Hotend Installation, X Carriage install: passo 5, immagine 1 di 3 CR-10 V2  Linear Rail Kit Hotend Installation, X Carriage install: passo 5, immagine 2 di 3 CR-10 V2  Linear Rail Kit Hotend Installation, X Carriage install: passo 5, immagine 3 di 3
    • Belt adaptor
    • 4x M3x8 SHCS
    • 3x M3 split washers
    • M3 Hex nuts
    • Install the M3x8 SHCS screw with M3 Split washer in to the X carriage adaptor plate and mount to the Rail block.
    • Push up on the belt bracket, it is square against the bottom of the carriage block.
    • Note: If screws will not start, threading in. Spin the screws counterclockwise until you hear a click, and then tighten the screws evenly in an X pattern until they are fully tightened. This is to ensure that the threads do not get damaged.
    • Note, reference Hotend Mounting Instructions section before mounting the MGN 12 Adaptor Plates to the linear rail block. For installing Hex Nuts to the back of the Adaptors.
  6. CR-10 V2  Linear Rail Kit Hotend Installation, Linear Rail Kit Hotend Install: passo 6, immagine 1 di 1
    • All Stock hotend and extruder mounting screws are re-used for the CR10 V2/V2
    • M3x6 BHCS (+2mm longer than stock) screws are used to mount the stock Bl Touch bracket.
Conclusione
AJ Pereira
Membro da: 05/29/20
2.735 Reputazione
16 Guide realizzate
Tiny Machines 3D Membro di Tiny Machines 3D
Community
5 Membri
41 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 32
Tutti i Tempi: 2,279
