Salta al contenuto principale
CM Storm QuickFire Rapid O-ring: Large Keycap Installation
Cosa ti serve
  1. CM Storm QuickFire Rapid O-ring: Large Keycap Installation, O-ring: Large Keycap: passo 1, immagine 1 di 3 CM Storm QuickFire Rapid O-ring: Large Keycap Installation, O-ring: Large Keycap: passo 1, immagine 2 di 3 CM Storm QuickFire Rapid O-ring: Large Keycap Installation, O-ring: Large Keycap: passo 1, immagine 3 di 3
  2. CM Storm QuickFire Rapid O-ring: Large Keycap Installation: passo 2, immagine 1 di 1
    • Pull the large keycap upward with your fingers until the cap separates from the plastic rings underneath the cap. If the metal bar beneath the cap comes loose during removal, snap it back in place.
  3. CM Storm QuickFire Rapid O-ring: Large Keycap Installation: passo 3, immagine 1 di 3 CM Storm QuickFire Rapid O-ring: Large Keycap Installation: passo 3, immagine 2 di 3 CM Storm QuickFire Rapid O-ring: Large Keycap Installation: passo 3, immagine 3 di 3
    • Remove the plastic rings from the keycap.
  4. CM Storm QuickFire Rapid O-ring: Large Keycap Installation: passo 4, immagine 1 di 2 CM Storm QuickFire Rapid O-ring: Large Keycap Installation: passo 4, immagine 2 di 2
    • Place the O-rings around the nubs underneath the keycap at each circled locations.
Conclusione
Cal Poly, Team 6-23, Maness Fall 2014 Membro di Cal Poly, Team 6-23, Maness Fall 2014
CPSU-MANESS-F14S6G23
4 Membri
12 Guide realizzate
Un commento
Best choice if you want all the “click” but none of the “clack” on your mechanical keyboard
Cherry Mx Black Rubber O-rings (125 pcs -EPDM – 40A) €3,98
Cherry Mx Black Rubber O-rings (90 pcs -EPDM – 40A) €3,48
[NL] O-rings Webstore http://tigri.bigcartel.com
Specs
Material: EPDM Industrial Grade Rubber
Color: Black
Hardness: 40A
Thickness: 1,50 mm (0.059 in)
Packaging: 125 pcs/bag or 90 pcs/bag
tigriorings - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,976
