Introduzione
Do you need to replace the barrel of your CHI Spin N Curl Rotating Curler? If so, this guide is for you. This guide will walk you threw the replacement process in eight steps. Make sure you have a 2.0 mm Flathead Screwdriver, Metal Spudger and a Phillips screwdriver for this guide.
Cosa ti serve
After following steps to open the CHI Spin N Curl, locate the heating element.
Remove screws on both sides of the heating element.
Once screws have been removed, then remove the heating element component.
Replace heating element once the original has been removed.
Remove all visible screws located near the barrel of the CHI Spin N Curl utilizing a Phillips #00 screwdriver.
Altre 2 persone hanno completato questa guida.
