Introduzione
This guide is for replacing the heating element of the CHI Spin N Curl rotating curler, model number CA2288A. Due to a defect in the heating element, the appliance may not heat up. To solve this problem, you must replace the ceramic fuse located under the heating element.
To get more details about the product visit the owners instructions.Â
Note that you will need to disconnect a battery while following the safety instructions.
Cosa ti serve
After following steps to open the CHI Spin N Curl, locate the heating element.
Remove screws on both sides of the heating element.
Once screws have been removed, then remove the heating element component.
Replace heating element once the original has been removed.
Altre 2 persone hanno completato questa guida.
