Salta al contenuto principale
CHI Spin N Curl Rotating Curler Directional Buttons Replacement
Cosa ti serve
  1. CHI Spin N Curl Rotating Curler Directional Buttons Replacement, Power Cord: passo 1, immagine 1 di 1
    • Use a metal spudger to pry off the silver, shiny trim.
  2. CHI Spin N Curl Rotating Curler Directional Buttons Replacement: passo 2, immagine 1 di 1
    • Remove inner black housing of the CHI Spin N Curl using the metal spudger to pop it out.
  3. CHI Spin N Curl Rotating Curler Directional Buttons Replacement: passo 3, immagine 1 di 2 CHI Spin N Curl Rotating Curler Directional Buttons Replacement: passo 3, immagine 2 di 2
    • Use a 2 mm flathead to remove the two screws.
  4. CHI Spin N Curl Rotating Curler Directional Buttons Replacement: passo 4, immagine 1 di 2 CHI Spin N Curl Rotating Curler Directional Buttons Replacement: passo 4, immagine 2 di 2
    • Use a metal spudger to pry open the seams of the device.
  5. CHI Spin N Curl Rotating Curler Directional Buttons Replacement: passo 5, immagine 1 di 3 CHI Spin N Curl Rotating Curler Directional Buttons Replacement: passo 5, immagine 2 di 3 CHI Spin N Curl Rotating Curler Directional Buttons Replacement: passo 5, immagine 3 di 3
    • Toward the bottom of the device, grab the swivel power cord.
    • Gently pull the power cord to detach it from the CHI Spin N Curl
    • Replace the faulty cord when the original cord has been removed.
  6. CHI Spin N Curl Rotating Curler Directional Buttons Replacement, Motherboard: passo 6, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the screws holding the barrel in.
  7. CHI Spin N Curl Rotating Curler Directional Buttons Replacement: passo 7, immagine 1 di 1
    • Remove the screws using Phillips #00 screwdriver and take off the components.
    • Once all screws are removed, take out the barrel accessing the motherboard underneath.
  8. CHI Spin N Curl Rotating Curler Directional Buttons Replacement: passo 8, immagine 1 di 1
    • Using metal spudger, lift and remove the motherboard and disconnect the top components.
  9. CHI Spin N Curl Rotating Curler Directional Buttons Replacement, Directional Buttons: passo 9, immagine 1 di 1
    • After the motherboard is removed, use the metal spudger to push and remove the directional buttons, and wipe underneath with a slightly damp alcohol cotton pad.
Conclusione
UMass Dartmouth, Team 2-7, Petersen Fall 2022 Membro di UMass Dartmouth, Team 2-7, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G7
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 21
Tutti i Tempi: 372
