Salta al contenuto principale
CHI Original Power Cord Replacement
Cosa ti serve
  1. CHI Original Power Cord Replacement, Hinge Spring: passo 1, immagine 1 di 2 CHI Original Power Cord Replacement, Hinge Spring: passo 1, immagine 2 di 2
    • Insert a nylon or metal spudger under the plastic CHI spring covers. Pry them up to pop them off. Do this for each side.
  2. CHI Original Power Cord Replacement: passo 2, immagine 1 di 1
    • Remove the .53" long screw from the hinge pin.
  3. CHI Original Power Cord Replacement: passo 3, immagine 1 di 1
    • Remove the hinge pin.
  4. CHI Original Power Cord Replacement: passo 4, immagine 1 di 1
    • Separate the two halves of the CHI Original.
  5. CHI Original Power Cord Replacement: passo 5, immagine 1 di 2 CHI Original Power Cord Replacement: passo 5, immagine 2 di 2
    • Remove the spring pin with a pair of pliers or tweezers.
    • Remove the spring.
  6. CHI Original Power Cord Replacement, Power Cord: passo 6, immagine 1 di 2 CHI Original Power Cord Replacement, Power Cord: passo 6, immagine 2 di 2
    • Remove (2) .31" Phillips head screws from back cover.
    • Remove cover.
  7. CHI Original Power Cord Replacement: passo 7, immagine 1 di 1
    • Gently pull upwards on the connection point and disconnect the power cord.
Conclusione
Eric Knigga
Membro da: 08/23/17
215 Reputazione
2 Guide realizzate
IUPUI, Team S1-G2, Freund Fall 2017 Membro di IUPUI, Team S1-G2, Freund Fall 2017
IUPUI-FREUND-F17S1G2
4 Membri
3 Guide realizzate
5 Commenti
Do you know where to get a replacement power cord?
Taylor Bradford - Replica
How/where do you purchase the replacement cord?
fixitman - Replica
Where do you order an actual cord from??
Kelly Hickman - Replica
Where we can get Power Cord?
Nazim - Replica
Bonjour Nazim, j'ai trouvé le bon câble pour réparer le modèle GF1001EUN Farouk Systems USA sur le site web de pgservice :
Hi Nazim, I found the right cable to repair the GF1001EUN Farouk Systems USA model on the pgservice website :
https://pgservice.cc/fr/products/gammapi...
Sonny -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 107
Tutti i Tempi: 6,098
