Introduzione
This guide will go over removing the CAT S22 FLIP's speaker. The speaker allows the user to be able to hear calls and any audio the device might emit.
A failing or faulty speaker would cause the phone to lose audio, rendering it unusable for calls.
Cosa ti serve
Unscrew the large screw on the back of the phone using a flathead screwdriver or coin.
Remove the six 3.8 mm-long screws from the back frame using a J00 screwdriver.
Remove the two 3.8 mm-long screws with rubber washers using a J00 screwdriver.
Remove the four 2.4 mm-long screws from the back frame using the J00 screwdriver.
Placing the Spudger at one end of the metallic connector of the daughterboard ribbon, apply a light upward pressure. The connector should slightly loosen from the motherboard, but not completely disconnect.
Move the spudger across the bottom of the connector, apply a rhythmic upward force as you go. The ribbon cable should disconnect.
If the daughterboard ribbon cable does not disconnect, repeat the previous instruction until it does. Do not apply too much upward force or use the motherboard as leverage even if the ribbon cable doesn’t disconnect.
After heating up the IOpener, use it to soften the adhesive around the speaker.
To reassemble your device, follow these instructions in reverse order. You may want to add additional adhesive to the speaker.
