Salta al contenuto principale
CAT S22 Flip Battery Replacement
Cosa ti serve
  1. CAT S22 Flip Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Unscrew the large screw on the back of the phone using a flathead screwdriver or coin.
    • The screw will always be completely unscrewed after 4 full counter-clockwise rotations.
    • The screw cannot be completely removed so that you can’t lose the screw.
    Chiedi a FixBot
  2. CAT S22 Flip Battery Replacement: passo 2, immagine 1 di 1
    • There is a slot on the upper left side of the back plate to insert the Spudger.
    • Use a spudger to pry up the back plate.
    Chiedi a FixBot
  3. CAT S22 Flip Battery Replacement: passo 3, immagine 1 di 1
    • There is a slot to insert a spudger at the bottom of the battery.
    • Use a spudger to lift the battery out of the phone.
    • Do not operate on a devise with a swollen battery. Do not dispose of a swollen battery into general waste systems. You can dispose of the batteries with a qualified technician or facility.
    Chiedi a FixBot
Conclusione
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 9
Ultimi 30 giorni: 46
Tutti i Tempi: 200
