Salta al contenuto principale
CAT S22 Flip Back Screen Replacement
Cosa ti serve
  1. CAT S22 Flip Back Screen Replacement, Back Screen: passo 1, immagine 1 di 3 CAT S22 Flip Back Screen Replacement, Back Screen: passo 1, immagine 2 di 3 CAT S22 Flip Back Screen Replacement, Back Screen: passo 1, immagine 3 di 3
    • Insert a metal spudger into the seam of the phone frame.
    • Apply a downward force on the metal spudger to create a gap.
    Chiedi a FixBot
  2. CAT S22 Flip Back Screen Replacement: passo 2, immagine 1 di 1
    • Insert a jimmy into the gap.
    • Use the jimmy to wedge the front panel free from the frame.
    • There is adhesive binding the front panel to the frame, so you will have to apply a moderate amount of force to get them apart.
    Chiedi a FixBot
  3. CAT S22 Flip Back Screen Replacement: passo 3, immagine 1 di 1
    • Use a J00 JIS screwdriver to remove the four wide 3.3 mm-long screws.
    • Use a J00 JIS screwdriver to remove the four narrow 3.3 mm-long screws.
    Chiedi a FixBot
  4. CAT S22 Flip Back Screen Replacement: passo 4, immagine 1 di 2 CAT S22 Flip Back Screen Replacement: passo 4, immagine 2 di 2
    • Use a metal spudger to dislodge the lip holding the frame together.
    Chiedi a FixBot
  5. CAT S22 Flip Back Screen Replacement: passo 5, immagine 1 di 1
    • Use the flat end of a spudger to gently disconnect the back screen press connector.
    Chiedi a FixBot
  6. CAT S22 Flip Back Screen Replacement: passo 6, immagine 1 di 1
    • Gently remove the back screen.
    Chiedi a FixBot
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 15
Ultimi 30 giorni: 70
Tutti i Tempi: 314
