Salta al contenuto principale
CASIO fx-570MS Battery Replacement
Cosa ti serve
  1. CASIO fx-570MS Battery Replacement, charger: passo 1, immagine 1 di 2 CASIO fx-570MS Battery Replacement, charger: passo 1, immagine 2 di 2
    • Flip the calculator over so the bottom is facing upwards.
  2. CASIO fx-570MS Battery Replacement: passo 2, immagine 1 di 3 CASIO fx-570MS Battery Replacement: passo 2, immagine 2 di 3 CASIO fx-570MS Battery Replacement: passo 2, immagine 3 di 3
    • Remove the screw from the battery hatch on the top-right corner using a 1.5 mm slotted screwdriver.
    • Remove the battery hatch.
  3. CASIO fx-570MS Battery Replacement: passo 3, immagine 1 di 3 CASIO fx-570MS Battery Replacement: passo 3, immagine 2 di 3 CASIO fx-570MS Battery Replacement: passo 3, immagine 3 di 3
    • Insert a spudger into the dent to the left of the battery until it hits the bottom of the panel board.
    • To create leverage, gently push the spudger towards the bottom of the battery (pushing your hand downwards and towards the back cover if necessary) to lift the battery out of its compartment.
    • Caution: Be careful to not rupture the battery or damage the panel board.
  4. CASIO fx-570MS Battery Replacement: passo 4, immagine 1 di 3 CASIO fx-570MS Battery Replacement: passo 4, immagine 2 di 3 CASIO fx-570MS Battery Replacement: passo 4, immagine 3 di 3
    • When you insert the new battery into the battery compartment, it should remain bulged upwards on the side towards the dent.
    • Make sure the flat side of the battery is facing upwards.
    • To finish inserting the new battery into the battery compartment, gently press the bulged corner with your finger until it slides into place.
  5. CASIO fx-570MS Battery Replacement: passo 5, immagine 1 di 2 CASIO fx-570MS Battery Replacement: passo 5, immagine 2 di 2
    • Close the plastic hatch and secure the screw.
  6. CASIO fx-570MS Battery Replacement: passo 6, immagine 1 di 2 CASIO fx-570MS Battery Replacement: passo 6, immagine 2 di 2
    • Flip the calculator on its back and press the 'ON' button to power it up.
    • A zero will appear on the bottom right corner of the LED display.
Conclusione
Your beloved CASIO fx-570MS Scientific Calculator is good to go for another few years.
Altre 3 persone hanno completato questa guida.
Un commento
How much does the battery cost?
Tamanna - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 29
Ultimi 7 Giorni: 203
Ultimi 30 Giorni: 753
Tutti i Tempi: 41,144
