Salta al contenuto principale
CASIO CDP-230R Main Circuit Board Replacement
Cosa ti serve
  1. CASIO CDP-230R Main Circuit Board Replacement, Panels: passo 1, immagine 1 di 3 CASIO CDP-230R Main Circuit Board Replacement, Panels: passo 1, immagine 2 di 3 CASIO CDP-230R Main Circuit Board Replacement, Panels: passo 1, immagine 3 di 3
    • Flip the keyboard upside down, with the keys on a flat surface.
    • Remove the three black 14mm Japanese Industrial Standard (J) head screws using a J1 screwdriver on the top half of the outermost side panel.
  2. CASIO CDP-230R Main Circuit Board Replacement: passo 2, immagine 1 di 3 CASIO CDP-230R Main Circuit Board Replacement: passo 2, immagine 2 di 3 CASIO CDP-230R Main Circuit Board Replacement: passo 2, immagine 3 di 3
    • Use two hands to grab the side panel from both sides.
    • Pull the panel apart from the device one side at a time.
    • There will be popping sounds when you remove this panel.
    • One side panel will not have an orange & white cable connected to it.
  3. CASIO CDP-230R Main Circuit Board Replacement: passo 3, immagine 1 di 3 CASIO CDP-230R Main Circuit Board Replacement: passo 3, immagine 2 di 3 CASIO CDP-230R Main Circuit Board Replacement: passo 3, immagine 3 di 3
    • Remove the three silver 10mm screws with a J1 screwdriver on the bottom half of the innermost side panel of the device.
    • One side panel will not have an orange & white cable running through.
  4. CASIO CDP-230R Main Circuit Board Replacement: passo 4, immagine 1 di 3 CASIO CDP-230R Main Circuit Board Replacement: passo 4, immagine 2 di 3 CASIO CDP-230R Main Circuit Board Replacement: passo 4, immagine 3 di 3
    • Remove the innermost side panel by pinching the top and bottom of the panel and pulling the panel off with both hands.
    • Repeat steps one through four to remove the other side panel of the keyboard.
  5. CASIO CDP-230R Main Circuit Board Replacement: passo 5, immagine 1 di 3 CASIO CDP-230R Main Circuit Board Replacement: passo 5, immagine 2 di 3 CASIO CDP-230R Main Circuit Board Replacement: passo 5, immagine 3 di 3
    • Remove the two black 30 mm J head screws with a J1 screwdriver to remove the long black bar.
    • Remove the four silver 8mm x 2mm J head screws with a J1 screwdriver and the two brackets from the back panel.
    • There will be two screws per bracket.
  6. CASIO CDP-230R Main Circuit Board Replacement: passo 6, immagine 1 di 3 CASIO CDP-230R Main Circuit Board Replacement: passo 6, immagine 2 di 3 CASIO CDP-230R Main Circuit Board Replacement: passo 6, immagine 3 di 3
    • Remove the eight silver 10mm x 1.5mm J head screws with a J1 screwdriver and the square tabs from the back panel.
    • Remove the eight silver 10mm J head screws with a J1 screwdriver underneath the square tabs.
  7. CASIO CDP-230R Main Circuit Board Replacement: passo 7, immagine 1 di 3 CASIO CDP-230R Main Circuit Board Replacement: passo 7, immagine 2 di 3 CASIO CDP-230R Main Circuit Board Replacement: passo 7, immagine 3 di 3
    • Remove the 36 silver 10mm J head screws with a J1 screwdriver from the back panel.
  8. CASIO CDP-230R Main Circuit Board Replacement: passo 8, immagine 1 di 3 CASIO CDP-230R Main Circuit Board Replacement: passo 8, immagine 2 di 3 CASIO CDP-230R Main Circuit Board Replacement: passo 8, immagine 3 di 3
    • Place a hand on the front panel and speakers and carefully flip the keyboard over with the keys facing up.
    • Having a extra pair of hands will be useful.
    • Grab the center of the front panel with two hands and lift to remove panel.
    • Grab the speakers from the sides and lift to remove. Once you have done this for the first speaker, repeat with the second speaker.
  9. CASIO CDP-230R Main Circuit Board Replacement, Main Circuit Board: passo 9, immagine 1 di 2 CASIO CDP-230R Main Circuit Board Replacement, Main Circuit Board: passo 9, immagine 2 di 2
    • The main circuit board is located on the green side of the button panel. The main circuit board is the smaller green board.
    • Grasp the white ribbon lined with foam and pull up to remove from the main circuit board.
    • Remove the four silver 8mm x 2mm J head screws with a J1 screwdriver.
  10. CASIO CDP-230R Main Circuit Board Replacement: passo 10, immagine 1 di 1
    • Lift the main circuit board from the button panel.
  11. CASIO CDP-230R Main Circuit Board Replacement: passo 11, immagine 1 di 3 CASIO CDP-230R Main Circuit Board Replacement: passo 11, immagine 2 di 3 CASIO CDP-230R Main Circuit Board Replacement: passo 11, immagine 3 di 3
    • Grip the white plastic end of the orange and white cables that is attached to the right side of the main circuit board and pull to the right.
    • Repeat for the orange and white cables attached to the left side of the main circuit board and pull up.
Conclusione
Altre 2 persone hanno completato questa guida.
Gavin Chao
Membro da: 10/02/17
191 Reputazione
1 Guida realizzata
Cal Poly, Team S4-G2, Livingston Fall 2017 Membro di Cal Poly, Team S4-G2, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G2
4 Membri
6 Guide realizzate
2 Commenti
Уважаемый fixit это димитрий фенетов твой чертовски мертвый
Roman Ambramovich - Replica
дорогой ifixit ваша ложь не является исключительной
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 22
Tutti i Tempi: 1,762
