Salta al contenuto principale
CASIO CDP-230R Key Replacement
Cosa ti serve
  1. CASIO CDP-230R Key Replacement, Panels: passo 1, immagine 1 di 3 CASIO CDP-230R Key Replacement, Panels: passo 1, immagine 2 di 3 CASIO CDP-230R Key Replacement, Panels: passo 1, immagine 3 di 3
    • Flip the keyboard upside down, with the keys on a flat surface.
    • Remove the three black 14mm Japanese Industrial Standard (J) head screws using a J1 screwdriver on the top half of the outermost side panel.
    We have this model and the pitch is bending intermittently on it’s own. Do you think disconnecting the bending ‘wheel’ would stop this or is it more likely to be a faulty chip?
    Thank you for any help!
    Ryan - Replica
  2. CASIO CDP-230R Key Replacement: passo 2, immagine 1 di 3 CASIO CDP-230R Key Replacement: passo 2, immagine 2 di 3 CASIO CDP-230R Key Replacement: passo 2, immagine 3 di 3
    • Use two hands to grab the side panel from both sides.
    • Pull the panel apart from the device one side at a time.
    • There will be popping sounds when you remove this panel.
    • One side panel will not have an orange & white cable connected to it.
  3. CASIO CDP-230R Key Replacement: passo 3, immagine 1 di 3 CASIO CDP-230R Key Replacement: passo 3, immagine 2 di 3 CASIO CDP-230R Key Replacement: passo 3, immagine 3 di 3
    • Remove the three silver 10mm screws with a J1 screwdriver on the bottom half of the innermost side panel of the device.
    • One side panel will not have an orange & white cable running through.
  4. CASIO CDP-230R Key Replacement: passo 4, immagine 1 di 3 CASIO CDP-230R Key Replacement: passo 4, immagine 2 di 3 CASIO CDP-230R Key Replacement: passo 4, immagine 3 di 3
    • Remove the innermost side panel by pinching the top and bottom of the panel and pulling the panel off with both hands.
    • Repeat steps one through four to remove the other side panel of the keyboard.
    In my model CDP230, upon removing the inner most side panel, 2 screw brackets will come loose each side. It will fall somewhere behind - you will need these when closing once again the panels. It has its own alcove but because the keyboard is now on its back (flipped), it will naturally fall out. What I did was to place the keyboard in its natural upright position when closing the inner and outer panel. And placing this screw bracket at closing the inner bracket.
    Tajuddin A - Replica
  5. CASIO CDP-230R Key Replacement: passo 5, immagine 1 di 3 CASIO CDP-230R Key Replacement: passo 5, immagine 2 di 3 CASIO CDP-230R Key Replacement: passo 5, immagine 3 di 3
    • Remove the two black 30 mm J head screws with a J1 screwdriver to remove the long black bar.
    • Remove the four silver 8mm x 2mm J head screws with a J1 screwdriver and the two brackets from the back panel.
    • There will be two screws per bracket.
  6. CASIO CDP-230R Key Replacement: passo 6, immagine 1 di 3 CASIO CDP-230R Key Replacement: passo 6, immagine 2 di 3 CASIO CDP-230R Key Replacement: passo 6, immagine 3 di 3
    • Remove the eight silver 10mm x 1.5mm J head screws with a J1 screwdriver and the square tabs from the back panel.
    • Remove the eight silver 10mm J head screws with a J1 screwdriver underneath the square tabs.
  7. CASIO CDP-230R Key Replacement: passo 7, immagine 1 di 3 CASIO CDP-230R Key Replacement: passo 7, immagine 2 di 3 CASIO CDP-230R Key Replacement: passo 7, immagine 3 di 3
    • Remove the 36 silver 10mm J head screws with a J1 screwdriver from the back panel.
  8. CASIO CDP-230R Key Replacement: passo 8, immagine 1 di 3 CASIO CDP-230R Key Replacement: passo 8, immagine 2 di 3 CASIO CDP-230R Key Replacement: passo 8, immagine 3 di 3
    • Place a hand on the front panel and speakers and carefully flip the keyboard over with the keys facing up.
    • Having a extra pair of hands will be useful.
    • Grab the center of the front panel with two hands and lift to remove panel.
    • Grab the speakers from the sides and lift to remove. Once you have done this for the first speaker, repeat with the second speaker.
    It seems impossible to take the front panel out unless I break it. How did you do it?
    Aaron Vincke - Replica
    I’m having the same issue. Did you ever figure out how to remove the front panel? Thanks
    silverbellrental - Replica
    My experience 1st time doing it was terrible because of the double sided adhesive tape applied by the factory. So with gentle traction and plenty of patience it did finally give way. The second time around it was much easier.
  9. CASIO CDP-230R Key Replacement, Key: passo 9, immagine 1 di 3 CASIO CDP-230R Key Replacement, Key: passo 9, immagine 2 di 3 CASIO CDP-230R Key Replacement, Key: passo 9, immagine 3 di 3
    • Locate the three screws behind the keys (left, center, and right).
    • Remove these 10mm J screws using a J1 screwdriver.
    • Grasp the white ribbon lined with foam and pull up to remove from the main circuit board.
  10. CASIO CDP-230R Key Replacement: passo 10, immagine 1 di 1
    • Place one hand on the side with fingers underneath the keys and one hand on the upper edge and lift off of the back panel.
    • Having an extra pair of hands will be useful.
  11. CASIO CDP-230R Key Replacement: passo 11, immagine 1 di 3 CASIO CDP-230R Key Replacement: passo 11, immagine 2 di 3 CASIO CDP-230R Key Replacement: passo 11, immagine 3 di 3
    • Pull up on the white key from the side nearest to you until the key lifts up.
    • Pull up on the two surrounding white keys before pulling up on the black key.
  12. CASIO CDP-230R Key Replacement: passo 12, immagine 1 di 3 CASIO CDP-230R Key Replacement: passo 12, immagine 2 di 3 CASIO CDP-230R Key Replacement: passo 12, immagine 3 di 3
    • Wiggle the white key from side to side and pull up to detach it from the rest of the board.
  13. CASIO CDP-230R Key Replacement: passo 13, immagine 1 di 3 CASIO CDP-230R Key Replacement: passo 13, immagine 2 di 3 CASIO CDP-230R Key Replacement: passo 13, immagine 3 di 3
    • To reattach the white key, snap the key back in place.
    • Flip the keyboard so the keys are laying on a flat surface.
    • Pull up on the black and white felt to dislodge the black shank.
    • Push up on the white key while pulling the felt up to reposition the black shank underneath the felt.
    Excellent ! blow - by - blow details ( until CASIO ultimately provides it )
    To keep our investment going … least until a slicker version comes out
    With awesome features , we might not be able to live without .
    rafael quinones - Replica
    Thank you very much. The instructions did take me all the way through to replace several ruptured black and white hammer caps. However, no pointers given here on cap replacement. Sharing for prosperity sake.
    Cap replacement is an easy affair. After removing the broken rubber pieces, remove excess grease to ease replacement. You should temporarily cover any holes with small piece of paper just in case the replacement cap slips from your finger and disappears. Identify correctly the B - black cap and W - white ones from you spare caps. The curved surface should be upward and the smaller opening slit should be facing inwards. Insert it using an above to below movement while holding the metal hammer steady. Don’t forget to reapply some grease upon completion.
    A reflection. A professional keyboard repairman did suggest a complete replacement of all the hammer caps as they tend to break / rupture approximately the same time. So I had to do this keyboard surgery twice over a period of less than 5 months.
Conclusione
To reassemble your device, follow step 13 and then the rest of the instructions in reverse order.
Altre 13 persone hanno completato questa guida.
Areli Reyes
Membro da: 10/01/17
545 Reputazione
4 Guide realizzate
Cal Poly, Team S4-G2, Livingston Fall 2017 Membro di Cal Poly, Team S4-G2, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G2
4 Membri
6 Guide realizzate
11Commenti sulla guida
Thankyou very much - I have a CDP-200R that I had to pull apart - yours was the only post I could find that helped me decode what it took!
rooster0001 - Replica
Me too, I have 200R need to replace the keys, but afraid to dismantle , now you save us all.thank you
Rus Azdy Ezzat Mohd Idrus -
Searched everywhere on how to fix my Casio CDP-220RBK and this was all I could find that actually helped! Awesome and very helpful guide!!!
albert einstien - Replica
Thanks a lot. This manual is very detailed, and the only one I've found in the whole Internet.
Владимир Белявский - Replica
Hello,
One of my kids lifted a black key from my piano. It won't come down fully and doesn't play when pressed. It's also harder to press, with more resistance.
Will I be able to put it back in place by following these instructions?
Many thanks.
Bernard Déry - Replica
Superb,
Felt like a genius managed to fix a dodgy key with a bit of rubbing alcohol and compressed air using this method.
I just had issue removing the key, On the 220RBK You have to lift the key up, then remove the shank from behind the felt as you later demonstrate. So a bit more fidly, but that wasn’t to hard to figure out on my own. Maybe worth a note on the guide?
Thanks for the super guide
Joshua hickin - Replica
I just posted a reference to this website at the Casio Music Forums user group.
JPizmo Clam - Replica
I need a complet set of hammer caps for my casio cdp 200.
How can I order it?
Could you help me on it?
Thanks
ctleonor - Replica
replacement parts list is all that’s missing ( thanks for opening the curtain , areli & company ) ;
Thank you for this helpful guide. Our son pulled up some keys on ours, and I was very happy to find your instructions. Your steps and photos made it very easy!
JFair - Replica
Does this work with a casio cdp s150? I can't seem to lift the keys up
Joseph O'Neill - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 50
Ultimi 30 Giorni: 133
Tutti i Tempi: 12,602
