Salta al contenuto principale
C-shaped Shower Door Handle Replacement
Cosa ti serve
  1. C-shaped Shower Door Handle Replacement, C-shaped Shower Door Handle: passo 1, immagine 1 di 3 C-shaped Shower Door Handle Replacement, C-shaped Shower Door Handle: passo 1, immagine 2 di 3 C-shaped Shower Door Handle Replacement, C-shaped Shower Door Handle: passo 1, immagine 3 di 3
    • Locate the socket head cap screw on the bottom arm of one door handle.
    • Only one handle will have the cap screws—one on the top and one on the bottom arm.
    • Insert the Allen wrench into the cap screw hole.
    • Rotate the Allen wrench counterclockwise to loosen the screw.
  2. C-shaped Shower Door Handle Replacement: passo 2, immagine 1 di 2 C-shaped Shower Door Handle Replacement: passo 2, immagine 2 di 2
    • Once the screw has been loosened, gently pull the handle away from the door.
  3. C-shaped Shower Door Handle Replacement: passo 3, immagine 1 di 1
    • Repeat steps 1 and 2 for the top of the handle.
    • Carefully remove the handle.
  4. C-shaped Shower Door Handle Replacement: passo 4, immagine 1 di 2 C-shaped Shower Door Handle Replacement: passo 4, immagine 2 di 2
    • On the remaining handle, insert the Phillips #2 screwdriver into the bottom screw.
    • Turn the screwdriver counterclockwise to loosen the screw.
    • Remove the screw cap, screw, and washer.
    • There may be several parts to the screw and washer set. This example has a brass screw cap, a screw, a larger 1.25" metal washer and plastic washer, and the interior, 3/4" plastic washer.
  5. C-shaped Shower Door Handle Replacement: passo 5, immagine 1 di 1
    • Disassemble the screw and washer set.
    • Remove the old or damaged interior plastic washer and discard.
  6. C-shaped Shower Door Handle Replacement: passo 6, immagine 1 di 3 C-shaped Shower Door Handle Replacement: passo 6, immagine 2 di 3 C-shaped Shower Door Handle Replacement: passo 6, immagine 3 di 3
    • Slide the new plastic washer onto the screw.
    • This may require threading the washer onto the screw if the hole is snug.
    • After you have threaded the new washer, reassemble the remaining parts of the screw set in reverse order.
  7. C-shaped Shower Door Handle Replacement: passo 7, immagine 1 di 2 C-shaped Shower Door Handle Replacement: passo 7, immagine 2 di 2
    • Insert the threaded screw set back through the shower door and handle.
    • Tighten the screw with the Phillips screwdriver, taking care not to overtighten or strip the screw.
  8. C-shaped Shower Door Handle Replacement: passo 8, immagine 1 di 1
    • Repeat steps 4-7 with the top screw.
  9. C-shaped Shower Door Handle Replacement: passo 9, immagine 1 di 2 C-shaped Shower Door Handle Replacement: passo 9, immagine 2 di 2
    • Once both screws are tightened, slide the other handle back onto the screws.
  10. C-shaped Shower Door Handle Replacement: passo 10, immagine 1 di 2 C-shaped Shower Door Handle Replacement: passo 10, immagine 2 di 2
    • Tighten the cap screw on the top part of the handle with the Allen wrench.
  11. C-shaped Shower Door Handle Replacement: passo 11, immagine 1 di 1
    • Repeat with the bottom cap screw.
  12. C-shaped Shower Door Handle Replacement: passo 12, immagine 1 di 1
    • Test both sides of the handle by gripping each one and gently pulling them back and forth.
    • If the handle is properly secure, there should be no movement.
Linea Traguardo
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 26
Ultimi 30 Giorni: 87
Tutti i Tempi: 635
