Salta al contenuto principale
C-Clamp Sternum Strap Replacement
  1. C-Clamp Sternum Strap Replacement, C-Clamp Sternum Strap Replacement: passo 1, immagine 1 di 2 C-Clamp Sternum Strap Replacement, C-Clamp Sternum Strap Replacement: passo 1, immagine 2 di 2
    • Locate the sternum strap that has come off the pack.
    • Replacements for this style of sternum strap are not currently available, so if part or all of the sternum strap is missing, reach out to Patagonia for alternative options.
  2. C-Clamp Sternum Strap Replacement: passo 2, immagine 1 di 3 C-Clamp Sternum Strap Replacement: passo 2, immagine 2 di 3 C-Clamp Sternum Strap Replacement: passo 2, immagine 3 di 3
    • The 'c-clamp' piece of the sternum strap fits over a plastic tube or ‘rail’ that is inside the backpack strap. At the bottom of this rail there is a fabric flap.
    • Pull back the fabric flap to expose where the rail ends. This is where the c-clamp was designed to be slid on and off.
    • At the exposed area at the base of the rail, slide the c-clamp back onto the rail.
    • Pull tightly on the fabric flap to expose the area.
    • Maneuver as if parallel parking a car. Start at an angle, slide partially onto the rail, and then straighten out.
    • This can be difficult to do, don’t be shy using some muscle!
    • Repeat the steps above on the other backpack strap.
  3. C-Clamp Sternum Strap Replacement: passo 4, immagine 1 di 2 C-Clamp Sternum Strap Replacement: passo 4, immagine 2 di 2
    • Slide the sternum strap to your desired position.
    • Hit the trails with your newly attached sternum strap!
Linea Traguardo
Zach Mueller
Membro da: 02/23/23
1.756 Reputazione
9 Guide realizzate
2Commenti sulla guida
This is helpful, except where do I find the replacement part! I contacted Patagonia and they no longer make it; they said to try a local sporting goods store or to send to Patagonia and they'll sew on a new daisy-chain version. My local REI does not have these parts either. Bummer!
Jornywar - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 138
Tutti i Tempi: 3,765
