Salta al contenuto principale
Brother XR-40 Stitch Select Knob Replacement
Cosa ti serve
  1. Brother XR-40 Stitch Select Knob Replacement, Back Panel: passo 1, immagine 1 di 1
    • Place the machine on a solid surface.
    • Remove the 14mm Phillips #2 screw holding on the face cover.
  2. Brother XR-40 Stitch Select Knob Replacement: passo 2, immagine 1 di 1
    • Remove the two 14mm Phillips #2 screws and two 22mm Phillips #2 screws that secure the rear casing.
  3. Brother XR-40 Stitch Select Knob Replacement: passo 3, immagine 1 di 1
    • Lay the machine on its side.
    • Remove the four 10mm Phillips #2 screws that hold the bottom panel in place.
    • The feet will come off with the screws.
  4. Brother XR-40 Stitch Select Knob Replacement: passo 4, immagine 1 di 1
    • Remove the bottom panel.
  5. Brother XR-40 Stitch Select Knob Replacement: passo 5, immagine 1 di 1
    • Place the machine upright.
    • Remove the rear casing.
    • You may have to wiggle the panel and pull at the same time.
  6. Brother XR-40 Stitch Select Knob Replacement, Stitch Select Knob: passo 6, immagine 1 di 1
    • Adjust the knob to gain access to the phillips head screw.
  7. Brother XR-40 Stitch Select Knob Replacement: passo 7, immagine 1 di 1
    • Remove the 14mm Phillips #2 screw.
  8. Brother XR-40 Stitch Select Knob Replacement: passo 8, immagine 1 di 1
    • Remove the knob.
Conclusione
Cal Poly, Team 2-12, Amido Winter 2014 Membro di Cal Poly, Team 2-12, Amido Winter 2014
CPSU-AMIDO-W14S2G12
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 22
Tutti i Tempi: 1,594
