Introduzione
Printing documents with the Brother Printer DCP-L2540DW requires the use of toner, but once that toner runs out it is time for it to get replaced. This helpful guide lays out clear and concise steps to assist you on how to replace an empty toner cartridge for your Brother Printer DCP-L2540DW with the correct toner sizes so that you can continue with your printing needs. Before attempting to replace the toner be sure to purchase one of the correct sizes. The TN660 allows for more uses than TN630, hence the reason why it costs more. Toner cartridges can be disposed of in the recycling bin. It is also important to note that contact with the printer transfer roller should be avoided as the toner can rub off onto the surrounding environment and can potentially make the toner cartridge ineffective.
2 Commenti
I have done this process and the printer is still telling saying that we need to put in toner?? Can not figure out why?? Any help??
It still tells me that I need to replace the toner can I get se help please
