Salta al contenuto principale
Brother Printer DCP-L2540DW Toner Cartridge Replacement
  1. Brother Printer DCP-L2540DW Toner Cartridge Replacement, Toner Cartridge: passo 1, immagine 1 di 1
    • Pull the center paper tray extender to expose the drum unit.
  2. Brother Printer DCP-L2540DW Toner Cartridge Replacement: passo 2, immagine 1 di 1
    • Gently pull the drum unit out of the printer at a slight incline angle.
  3. Brother Printer DCP-L2540DW Toner Cartridge Replacement: passo 3, immagine 1 di 2 Brother Printer DCP-L2540DW Toner Cartridge Replacement: passo 3, immagine 2 di 2
    • Push down on the lever lock to unlock the cartridge from the drum unit.
    • Remove the cartridge from the drum unit and recycle it.
  4. Brother Printer DCP-L2540DW Toner Cartridge Replacement: passo 4, immagine 1 di 2 Brother Printer DCP-L2540DW Toner Cartridge Replacement: passo 4, immagine 2 di 2
    • Unpack the new toner cartridge from its packaging.
    • Gently shake the cartridge to evenly distribute the toner throughout the printer transfer roller.
  5. Brother Printer DCP-L2540DW Toner Cartridge Replacement: passo 5, immagine 1 di 3 Brother Printer DCP-L2540DW Toner Cartridge Replacement: passo 5, immagine 2 di 3 Brother Printer DCP-L2540DW Toner Cartridge Replacement: passo 5, immagine 3 di 3
    • Remove protective cover enclosing the printer transfer roller
    • AVOID CONTACT WITH PRINTER TRANSFER ROLLER. This could potentially damage the device.
    • Insert the new cartridge in the drum unit.
    • A click should be heard to acknowledge the toner cartridge has been fitted properly.
  6. Brother Printer DCP-L2540DW Toner Cartridge Replacement: passo 6, immagine 1 di 3 Brother Printer DCP-L2540DW Toner Cartridge Replacement: passo 6, immagine 2 di 3 Brother Printer DCP-L2540DW Toner Cartridge Replacement: passo 6, immagine 3 di 3
    • Clean the corona wire with the slide tab near the front side of the drum unit by sliding it left and right several times.
    • Return the slide tab back to its original position before continuing.
  7. Brother Printer DCP-L2540DW Toner Cartridge Replacement: passo 7, immagine 1 di 3 Brother Printer DCP-L2540DW Toner Cartridge Replacement: passo 7, immagine 2 di 3 Brother Printer DCP-L2540DW Toner Cartridge Replacement: passo 7, immagine 3 di 3
    • Insert the drum unit with the new toner cartridge attached at a slight incline back into the printer.
    • Remember to have the drum unit pushed in enough for the front cover to be able to close.
    • You have now successfully completed replacing the toner cartridge for your Brother DCP-L2540DW Printer.
Conclusione
Garvish Patel
Membro da: 05/12/21
145 Reputazione
1 Guida realizzata
Un commento
I have done this process and the printer is still telling saying that we need to put in toner?? Can not figure out why?? Any help??
Ed Reinstein - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 38
Ultimi 30 Giorni: 201
Tutti i Tempi: 5,804
