Salta al contenuto principale
Brother PT-D200 LCD Screen Replacement
Cosa ti serve
  1. Brother PT-D200 LCD Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the device over and press down on the indication arrows located at the top center of the back cover and pull it open.
  2. Brother PT-D200 LCD Screen Replacement: passo 2, immagine 1 di 1
    • Remove the six AAA batteries.
  3. Brother PT-D200 LCD Screen Replacement, Back of Device: passo 3, immagine 1 di 1
    • Use the Helping Hand 1/4" screwdriver to unscrew the six 3/16" corner screws.
  4. Brother PT-D200 LCD Screen Replacement: passo 4, immagine 1 di 1
    • Close the back cover and then flip the device over and separate the top half from the bottom half as shown.
    • Be gentle when lifting the top of the device, there is a ribbon cable attaching the two halves together.
  5. Brother PT-D200 LCD Screen Replacement, Circuit Board Cables: passo 5, immagine 1 di 1
    • Gently pull out the ribbon cable from the circuit board.
    • The ribbon cable is very fragile.
  6. Brother PT-D200 LCD Screen Replacement: passo 6, immagine 1 di 1
    • Remove two-pin plastic connector from the circuit board.
    • Gently pull the two-pin connector from the circuit board to avoid damaging the board.
  7. Brother PT-D200 LCD Screen Replacement, Circuit Board: passo 7, immagine 1 di 2 Brother PT-D200 LCD Screen Replacement, Circuit Board: passo 7, immagine 2 di 2
    • Remove the two 3/16" screws from the circuit board using the Helping Hand 1/4" screwdriver.
  8. Brother PT-D200 LCD Screen Replacement: passo 8, immagine 1 di 1
    • Release the two black clips that hold the LCD cable ribbon in place. To release, pull the clips towards the ribbon.
  9. Brother PT-D200 LCD Screen Replacement: passo 9, immagine 1 di 1
    • Disconnect the LCD ribbon cable from the circuit board.
  10. Brother PT-D200 LCD Screen Replacement, Face Plate: passo 10, immagine 1 di 1
    • On the top portion of the device there are four grey clips locking the faceplate in place. The two top clips are circled in the image. The two others are located in the other corners of the device.
  11. Brother PT-D200 LCD Screen Replacement: passo 11, immagine 1 di 2 Brother PT-D200 LCD Screen Replacement: passo 11, immagine 2 di 2
    • Pull the clips inward two at a time, first the top then the bottom, to snap the face plate off.
  12. Brother PT-D200 LCD Screen Replacement, Keyboard: passo 12, immagine 1 di 2 Brother PT-D200 LCD Screen Replacement, Keyboard: passo 12, immagine 2 di 2
    • Peel off the rubber keyboard of the device.
  13. Brother PT-D200 LCD Screen Replacement, LCD Screen: passo 13, immagine 1 di 2 Brother PT-D200 LCD Screen Replacement, LCD Screen: passo 13, immagine 2 di 2
    • Lift the LCD screen out of place.
Conclusione
Cal Poly, Team 13-16, Regan Winter 2014 Membro di Cal Poly, Team 13-16, Regan Winter 2014
CPSU-REGAN-W14S13G16
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 23
Tutti i Tempi: 1,741
