Salta al contenuto principale
Introduzione
This guide will walk you through the process of replacing the faceplate on a Brother PT-D200.
Parti
Nessuna parte specificata.
  1. Flip the device over and press down on the indication arrows located at the top center of the back cover and pull it open.
    • Flip the device over and press down on the indication arrows located at the top center of the back cover and pull it open.
  2. Remove the six AAA batteries.
    • Remove the six AAA batteries.
  3. Use the Helping Hand 1/4" screwdriver to unscrew the six 3/16" corner screws.
    • Use the Helping Hand 1/4" screwdriver to unscrew the six 3/16" corner screws.
  4. Kit di riparazione per Android
    A new screen or battery is one kit away.
    Acquista ora
    Acquista ora
  5. Close the back cover and then flip the device over and separate the top half from the bottom half as shown.
    • Close the back cover and then flip the device over and separate the top half from the bottom half as shown.
    • Be gentle when lifting the top of the device, there is a ribbon cable attaching the two halves together.
  6. Gently pull out the ribbon cable from the circuit board.
    • Gently pull out the ribbon cable from the circuit board.
    • The ribbon cable is very fragile.
  7. Remove two-pin plastic connector from the circuit board.
    • Remove two-pin plastic connector from the circuit board.
    • Gently pull the two-pin connector from the circuit board to avoid damaging the board.
  8. On the top portion of the device there are four grey clips locking the faceplate in place.  The two top clips are circled in the image. The two others are located in the other corners of the device.
    • On the top portion of the device there are four grey clips locking the faceplate in place. The two top clips are circled in the image. The two others are located in the other corners of the device.
  9. Pull the clips inward two at a time, first the top then the bottom, to snap the face plate off. Pull the clips inward two at a time, first the top then the bottom, to snap the face plate off.
    • Pull the clips inward two at a time, first the top then the bottom, to snap the face plate off.
Conclusione
[deleted]
Membro da: 24/01/2014
301 Reputazione
3 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 399
