Salta al contenuto principale
Brother PT-D200 Cutter Blade Replacement
  1. Brother PT-D200 Cutter Blade Replacement, Cutter Blade: passo 1, immagine 1 di 2 Brother PT-D200 Cutter Blade Replacement, Cutter Blade: passo 1, immagine 2 di 2
    • Open the back panel of the device by pressing down on and then pulling the indication arrows on the top center of the cover upward towards you.
  2. Brother PT-D200 Cutter Blade Replacement: passo 2, immagine 1 di 1
    • Locate the cutter blade unit (mint green) as shown in the picture.
  3. Brother PT-D200 Cutter Blade Replacement: passo 3, immagine 1 di 2 Brother PT-D200 Cutter Blade Replacement: passo 3, immagine 2 di 2
    • Using the thumb and forefinger, pull up, applying a moderate amount of pressure until the cutter blade unit loosens and is removed.
    • The blade is sharp.
Conclusione
Cal Poly, Team 13-16, Regan Winter 2014 Membro di Cal Poly, Team 13-16, Regan Winter 2014
CPSU-REGAN-W14S13G16
3 Membri
6 Guide realizzate
Un commento
Where can you order the replacement blade?
mistymeziere - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 43
Tutti i Tempi: 3,076
