Salta al contenuto principale
Parti
Nessuna parte specificata.
  1. Gently pull out the ribbon cable from the circuit board.
    • Gently pull out the ribbon cable from the circuit board.
    • The ribbon cable is very fragile.
  2. Remove two-pin plastic connector from the circuit board.
    • Remove two-pin plastic connector from the circuit board.
    • Gently pull the two-pin connector from the circuit board to avoid damaging the board.
  3. Kit riparazione batterie MacBook
    A partire da $69.99
    Buy Now
    A partire da $69.99
    Buy Now
  4. Remove the two 3/16" screws from the circuit board using the Helping Hand 1/4" screwdriver. Remove the two 3/16" screws from the circuit board using the Helping Hand 1/4" screwdriver.
    • Remove the two 3/16" screws from the circuit board using the Helping Hand 1/4" screwdriver.
  5. Release the two black clips that hold the LCD cable ribbon in place. To release, pull the clips towards the ribbon.
    • Release the two black clips that hold the LCD cable ribbon in place. To release, pull the clips towards the ribbon.
  6. Disconnect the LCD ribbon cable from the circuit board.
    • Disconnect the LCD ribbon cable from the circuit board.
Conclusione
Jeston Mitchell
Membro da: 24/01/2014
308 Reputazione
3 Guide realizzate
Cal Poly, Team 13-16, Regan Winter 2014 Membro di Cal Poly, Team 13-16, Regan Winter 2014
CPSU-REGAN-W14S13G16
3 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 28
