Salta al contenuto principale
Brother PT-90 Personal Labeler Disassembly
Cosa ti serve
  1. Brother PT-90 Personal Labeler Disassembly, Brother PT-90 Personal Labeler Disassembly: passo 1, immagine 1 di 2 Brother PT-90 Personal Labeler Disassembly, Brother PT-90 Personal Labeler Disassembly: passo 1, immagine 2 di 2
    • Start with your device off. The screen should be blank and not displaying anything.
    • Turn the device over so it's resting face down.
    • You should be able to see the model name of the label-maker, as well as a window in which you can view the label cartridge.
  2. Brother PT-90 Personal Labeler Disassembly: passo 2, immagine 1 di 3 Brother PT-90 Personal Labeler Disassembly: passo 2, immagine 2 di 3 Brother PT-90 Personal Labeler Disassembly: passo 2, immagine 3 di 3
    • Using your thumb, press in and then upward on the fastener at the top of the device. The back of the device should come off easily.
    • Remove the 4 batteries located on the left side of the device.
  3. Brother PT-90 Personal Labeler Disassembly: passo 3, immagine 1 di 3 Brother PT-90 Personal Labeler Disassembly: passo 3, immagine 2 di 3 Brother PT-90 Personal Labeler Disassembly: passo 3, immagine 3 di 3
    • To remove the label cartridge from the device, use a plastic opening tool from your iFixit tool kit.
  4. Brother PT-90 Personal Labeler Disassembly: passo 4, immagine 1 di 3 Brother PT-90 Personal Labeler Disassembly: passo 4, immagine 2 di 3 Brother PT-90 Personal Labeler Disassembly: passo 4, immagine 3 di 3
    • Attach the J1 Screwdriver Bit to the extension tool from your tool kit.
    • Remove all of the screws from the back of the device.
  5. Brother PT-90 Personal Labeler Disassembly: passo 5, immagine 1 di 2 Brother PT-90 Personal Labeler Disassembly: passo 5, immagine 2 di 2
    • Once the screws have been removed, press as shown on the fastener.
    • Carefully open the device.
Linea Traguardo
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 22
Tutti i Tempi: 865
