Salta al contenuto principale
Brother PT-1290 Keyboard Replacement
Cosa ti serve
  1. Brother PT-1290 Keyboard Replacement, Turn over device to remove batteries.: passo 1, immagine 1 di 3 Brother PT-1290 Keyboard Replacement, Turn over device to remove batteries.: passo 1, immagine 2 di 3 Brother PT-1290 Keyboard Replacement, Turn over device to remove batteries.: passo 1, immagine 3 di 3
    • Turn the device to it's side toward the bottom of the keyboard. Then pop open the case and remove the batteries.
  2. Brother PT-1290 Keyboard Replacement, Back of device: passo 2, immagine 1 di 3 Brother PT-1290 Keyboard Replacement, Back of device: passo 2, immagine 2 di 3 Brother PT-1290 Keyboard Replacement, Back of device: passo 2, immagine 3 di 3
    • Remove back of device and set aside.
  3. Brother PT-1290 Keyboard Replacement, Remove screws: passo 3, immagine 1 di 3 Brother PT-1290 Keyboard Replacement, Remove screws: passo 3, immagine 2 di 3 Brother PT-1290 Keyboard Replacement, Remove screws: passo 3, immagine 3 di 3
    • Remove all 1/4 inch screws(6 total) with a (+PH00) screwdriver. Open slowly not to damage the display data cable.
  4. Brother PT-1290 Keyboard Replacement, Remove flat panel: passo 4, immagine 1 di 3 Brother PT-1290 Keyboard Replacement, Remove flat panel: passo 4, immagine 2 di 3 Brother PT-1290 Keyboard Replacement, Remove flat panel: passo 4, immagine 3 di 3
    • Use a plastic opening tool to remove the flat-panel membrane keyboard. Lift up and set aside.
  5. Brother PT-1290 Keyboard Replacement, Remove: passo 5, immagine 1 di 3 Brother PT-1290 Keyboard Replacement, Remove: passo 5, immagine 2 di 3 Brother PT-1290 Keyboard Replacement, Remove: passo 5, immagine 3 di 3
    • Use a spudger to aid in removing the keyboard.
    • Gently lift out while removing the LCD screen that is connected to the data cable and finishing removing.
Conclusione
Gateway, Team 1-4, Johnson Fall 2014 Membro di Gateway, Team 1-4, Johnson Fall 2014
GCC-JOHNSON-F14S1G4
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 15
Tutti i Tempi: 489
