Salta al contenuto principale
Brother PT-1290 Battery/AC Adapter Replacment
  1. Brother PT-1290 Battery/AC Adapter Replacment, Brother PT-1290 Battery/AC Adapter: passo 1, immagine 1 di 3 Brother PT-1290 Battery/AC Adapter Replacment, Brother PT-1290 Battery/AC Adapter: passo 1, immagine 2 di 3 Brother PT-1290 Battery/AC Adapter Replacment, Brother PT-1290 Battery/AC Adapter: passo 1, immagine 3 di 3
    • First, flip over your label maker and push down on the top part(by the face plate) and push on the circle part with ridges. Next open the label maker carefully to prevent any damage.
  2. Brother PT-1290 Battery/AC Adapter Replacment: passo 2, immagine 1 di 1
    • Once the label maker is open, remove the six AAA drained batteries.
    • If your using an AC adapter, replace the old one with the new HQRP adapter.
    • If you see white on the batteries, that would be corrosion. Be careful when disposing.
  3. Brother PT-1290 Battery/AC Adapter Replacment: passo 3, immagine 1 di 3 Brother PT-1290 Battery/AC Adapter Replacment: passo 3, immagine 2 di 3 Brother PT-1290 Battery/AC Adapter Replacment: passo 3, immagine 3 di 3
    • Now place in the new six AAA batteries.
    • Make sure the batteries are correctly in and touching the golden prongs.
Conclusione
Gateway, Team 1-4, Johnson Fall 2014 Membro di Gateway, Team 1-4, Johnson Fall 2014
GCC-JOHNSON-F14S1G4
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 882
