Salta al contenuto principale
Brother PT-1290 Face Plate Replacement
Cosa ti serve
  1. Brother PT-1290  Face Plate Replacement, Turn over device to remove batteries.: passo 1, immagine 1 di 3 Brother PT-1290  Face Plate Replacement, Turn over device to remove batteries.: passo 1, immagine 2 di 3 Brother PT-1290  Face Plate Replacement, Turn over device to remove batteries.: passo 1, immagine 3 di 3
    • Turn the device to it's side toward the bottom of the keyboard. Then pop open the case and remove the batteries.
  2. Brother PT-1290  Face Plate Replacement, Back of device: passo 2, immagine 1 di 3 Brother PT-1290  Face Plate Replacement, Back of device: passo 2, immagine 2 di 3 Brother PT-1290  Face Plate Replacement, Back of device: passo 2, immagine 3 di 3
    • Remove back of device and set aside.
  3. Brother PT-1290  Face Plate Replacement, Remove screws: passo 3, immagine 1 di 3 Brother PT-1290  Face Plate Replacement, Remove screws: passo 3, immagine 2 di 3 Brother PT-1290  Face Plate Replacement, Remove screws: passo 3, immagine 3 di 3
    • Remove all 1/4 inch screws(6 total) with a (+PH00) screwdriver. Open slowly not to damage the display data cable.
  4. Brother PT-1290  Face Plate Replacement, Remove flat panel: passo 4, immagine 1 di 3 Brother PT-1290  Face Plate Replacement, Remove flat panel: passo 4, immagine 2 di 3 Brother PT-1290  Face Plate Replacement, Remove flat panel: passo 4, immagine 3 di 3
    • Use a plastic opening tool to remove the flat-panel membrane keyboard. Lift up and set aside.
  5. Brother PT-1290  Face Plate Replacement, Remove: passo 5, immagine 1 di 3 Brother PT-1290  Face Plate Replacement, Remove: passo 5, immagine 2 di 3 Brother PT-1290  Face Plate Replacement, Remove: passo 5, immagine 3 di 3
    • Use a spudger to aid in removing the keyboard.
    • Gently lift out while removing the LCD screen that is connected to the data cable and finishing removing.
  6. Brother PT-1290  Face Plate Replacement, Removing the LCD screen.: passo 6, immagine 1 di 3 Brother PT-1290  Face Plate Replacement, Removing the LCD screen.: passo 6, immagine 2 di 3 Brother PT-1290  Face Plate Replacement, Removing the LCD screen.: passo 6, immagine 3 di 3
    • Now that you have removed your keyboard. Turn the device over carefully.
    • Pop of LCD black cover.
    • Use the spudger to gently press out the LCD screen.
  7. Brother PT-1290  Face Plate Replacement, Switching out faceplate.: passo 7, immagine 1 di 1
    • Change out old damaged face plate with your new face plate.
Conclusione
Gateway, Team 1-4, Johnson Fall 2014 Membro di Gateway, Team 1-4, Johnson Fall 2014
GCC-JOHNSON-F14S1G4
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 9
Tutti i Tempi: 160
