Salta al contenuto principale
Brother PT-110 Printer Motor Replacement
Cosa ti serve
  1. Brother PT-110 Printer Motor Replacement, Batteries: passo 1, immagine 1 di 2 Brother PT-110 Printer Motor Replacement, Batteries: passo 1, immagine 2 di 2
    • Push on the side of the cover, and remove it.
  2. Brother PT-110 Printer Motor Replacement: passo 2, immagine 1 di 1
    • Remove the batteries.
  3. Brother PT-110 Printer Motor Replacement, Back Plate: passo 3, immagine 1 di 2 Brother PT-110 Printer Motor Replacement, Back Plate: passo 3, immagine 2 di 2
    • Unscrew the two 9 mm Phillips #1 screws from the top and bottom.
    • Total: 2 x Screws
  4. Brother PT-110 Printer Motor Replacement: passo 4, immagine 1 di 1
    • First: To separate the top cover from the body, insert a spudger between the two halves.
    • Gently twist the spudger until the two halves separate. Do this in multiple spots around the perimeter of the cover to distribute the pressure.
    • DO NOT PULL HALVES APART. There are wired connections inside that must be disconnected before halves can be fully separated.
  5. Brother PT-110 Printer Motor Replacement: passo 5, immagine 1 di 1
    • Gently separate the two covers, ensuring wires are not taut.
  6. Brother PT-110 Printer Motor Replacement: passo 6, immagine 1 di 1
    • Gently grasp the ribbon wire and top cover, then gently pull the ribbon wire out of its connection.
  7. Brother PT-110 Printer Motor Replacement: passo 7, immagine 1 di 2 Brother PT-110 Printer Motor Replacement: passo 7, immagine 2 di 2
    • Carefully pinch the top of the connector.
    • Pull perpendicular to the device until the wire is disconnected.
    • It may require more force than expected to disconnect the wires.
  8. Brother PT-110 Printer Motor Replacement: passo 8, immagine 1 di 3 Brother PT-110 Printer Motor Replacement: passo 8, immagine 2 di 3 Brother PT-110 Printer Motor Replacement: passo 8, immagine 3 di 3
    • Unscrew the three 9 mm Phillips #1 screws shown.
    • Total: 3 x Screws
  9. Brother PT-110 Printer Motor Replacement, Printer Motor: passo 9, immagine 1 di 1
    • Remove the motor housing.
  10. Brother PT-110 Printer Motor Replacement: passo 10, immagine 1 di 2 Brother PT-110 Printer Motor Replacement: passo 10, immagine 2 di 2
    • Unscrew the two 3 mm Phillips #1 screws from the motor housing.
    • Total: 2 x Screws
  11. Brother PT-110 Printer Motor Replacement: passo 11, immagine 1 di 1
    • Remove the motor.
Conclusione
IUPUI, Team 1-1, Harley Fall 2016 Membro di IUPUI, Team 1-1, Harley Fall 2016
IUPUI-HARLEY-F16S1G1
3 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 22
Tutti i Tempi: 803
