Salta al contenuto principale
Brother MFC-9130CW Ink Cartridge Replacement
Cosa ti serve
  1. Brother MFC-9130CW Ink Cartridge Replacement, Ink Cartridge Replacement: passo 1, immagine 1 di 1
    • Press the power button on the printer for a couple of seconds to turn it off.
  2. Brother MFC-9130CW Ink Cartridge Replacement: passo 2, immagine 1 di 2 Brother MFC-9130CW Ink Cartridge Replacement: passo 2, immagine 2 di 2
    • Press the latch beneath the paper output area and lift it to access the ink compartment.
  3. Brother MFC-9130CW Ink Cartridge Replacement: passo 3, immagine 1 di 1
    • Identify the specific ink color you wish to replace among the available cartridges in the ink compartment.
  4. Brother MFC-9130CW Ink Cartridge Replacement: passo 4, immagine 1 di 2 Brother MFC-9130CW Ink Cartridge Replacement: passo 4, immagine 2 di 2
    • Pull each ink cartridge tray out of its slot using the center handle.
  5. Brother MFC-9130CW Ink Cartridge Replacement: passo 5, immagine 1 di 2 Brother MFC-9130CW Ink Cartridge Replacement: passo 5, immagine 2 di 2
    • Place the new ink cartridge on a clean surface.
    • Release the orange cover, as shown on the photo.
    • To prevent making a mess, set a paper towel on the counter or table in case of a spill during the replacement process.
  6. Brother MFC-9130CW Ink Cartridge Replacement: passo 6, immagine 1 di 2 Brother MFC-9130CW Ink Cartridge Replacement: passo 6, immagine 2 di 2
    • Place the cartridge in the tray.
    • Gently press down on the ink tray with your thumb.
    • You should hear a click, ensuring that the new ink cartridge is secure in its place.
  7. Brother MFC-9130CW Ink Cartridge Replacement: passo 7, immagine 1 di 3 Brother MFC-9130CW Ink Cartridge Replacement: passo 7, immagine 2 di 3 Brother MFC-9130CW Ink Cartridge Replacement: passo 7, immagine 3 di 3
    • Slide the ink tray back into its original position within the printer.
    • Make sure it is properly aligned and secure within the compartment.
    • Once the ink tray is secured, press the ink compartment latch with your thumb, and gently close the lid.
  8. Brother MFC-9130CW Ink Cartridge Replacement: passo 8, immagine 1 di 1
    • Press the power button for a couple of seconds to turn the printer back on.
    • Print a couple of test copies to ensure the toner cartridge replacement was a success.
Conclusione
To reassemble your device, follow these instructions in the given order.
Kamaljot
Membro da: 01/08/24
184 Reputazione
1 Guida realizzata
Un commento
One step is missing : release the orange cover.
Artefil - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 74
Tutti i Tempi: 268
