Salta al contenuto principale
Brother MFC-490CW Wireless module Replacement
Cosa ti serve
  1. Brother MFC-490CW Wireless module Replacement, Remove screws holding the front panel: passo 1, immagine 1 di 1
    • Use a Phillips #2 screwdriver to remove the three 12.1 mm screws holding the control panel in place.
  2. Brother MFC-490CW Wireless module Replacement, Unplug the panel from the rest of the printer: passo 2, immagine 1 di 3 Brother MFC-490CW Wireless module Replacement, Unplug the panel from the rest of the printer: passo 2, immagine 2 di 3 Brother MFC-490CW Wireless module Replacement, Unplug the panel from the rest of the printer: passo 2, immagine 3 di 3
    • Lift up the front panel from the device.
    • Gently lift up and disconnect the data cables that attach the panel to the printer.
  3. Brother MFC-490CW Wireless module Replacement, Remove the screw: passo 3, immagine 1 di 1
    • Unscrew the 14.1mm screw located at the left side of the device.
    • Unscrew the 12.1mm screw to the right of the 14.1mm screw.
  4. Brother MFC-490CW Wireless module Replacement: passo 4, immagine 1 di 3 Brother MFC-490CW Wireless module Replacement: passo 4, immagine 2 di 3 Brother MFC-490CW Wireless module Replacement: passo 4, immagine 3 di 3
    • Pry open the left front panel away from the printer
    • Be careful. The panel is attached with a data cable.
  5. Brother MFC-490CW Wireless module Replacement: passo 5, immagine 1 di 2 Brother MFC-490CW Wireless module Replacement: passo 5, immagine 2 di 2
    • Carefully unplug the connector attached to the device.
  6. Brother MFC-490CW Wireless module Replacement, Remove the module from the panel: passo 6, immagine 1 di 3 Brother MFC-490CW Wireless module Replacement, Remove the module from the panel: passo 6, immagine 2 di 3 Brother MFC-490CW Wireless module Replacement, Remove the module from the panel: passo 6, immagine 3 di 3
    • Separate the two clips that hold the module in place.
    • Lift up the module.
Conclusione
To reassemble your wireless module, follow these instructions in reverse order.
Matt
Membro da: 10/30/14
64 Reputazione
2 Guide realizzate
UMass Dartmouth, Team 4-4, Miles Fall 2014 Membro di UMass Dartmouth, Team 4-4, Miles Fall 2014
UMASSD-MILES-F14S4G4
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 28
Tutti i Tempi: 1,733
