Salta al contenuto principale
Brother MFC-490CW Scanning Glass Replacement
Cosa ti serve
  1. Brother MFC-490CW Scanning Glass Replacement, Removing Scanner Header: passo 1, immagine 1 di 3 Brother MFC-490CW Scanning Glass Replacement, Removing Scanner Header: passo 1, immagine 2 di 3 Brother MFC-490CW Scanning Glass Replacement, Removing Scanner Header: passo 1, immagine 3 di 3
    • Twist green section to allow the scanner head to have a full range of motion.
  2. Brother MFC-490CW Scanning Glass Replacement, Removing Scan Header: passo 2, immagine 1 di 3 Brother MFC-490CW Scanning Glass Replacement, Removing Scan Header: passo 2, immagine 2 di 3 Brother MFC-490CW Scanning Glass Replacement, Removing Scan Header: passo 2, immagine 3 di 3
    • To remove scanner head, open it halfway as possible and slide the hinges out of place and the head will be removed.
  3. Brother MFC-490CW Scanning Glass Replacement, Remove scanner head connection to printer: passo 3, immagine 1 di 3 Brother MFC-490CW Scanning Glass Replacement, Remove scanner head connection to printer: passo 3, immagine 2 di 3 Brother MFC-490CW Scanning Glass Replacement, Remove scanner head connection to printer: passo 3, immagine 3 di 3
    • The panels to expose the cords will become exposed when the head is removed.
    • Pull all colored cords from the printer and unscrew the other wire to be fully removed.
    • Pull the black tab from the printer to remove.
  4. Brother MFC-490CW Scanning Glass Replacement, Removing the bottom screws: passo 4, immagine 1 di 2 Brother MFC-490CW Scanning Glass Replacement, Removing the bottom screws: passo 4, immagine 2 di 2
    • Once scanner is free from the printer remove all the screws on the bottom base
    • Use a #2 Philips head screw driver to remove the two 12.1mm screws.
  5. Brother MFC-490CW Scanning Glass Replacement, Exposing scanner glass: passo 5, immagine 1 di 3 Brother MFC-490CW Scanning Glass Replacement, Exposing scanner glass: passo 5, immagine 2 di 3 Brother MFC-490CW Scanning Glass Replacement, Exposing scanner glass: passo 5, immagine 3 di 3
    • To separate the base from the glass hold upright and separate along the edge where you removed the screws.
    • Use hands to expose the glass.
    • Keep track flat once glass is removed as to not lose little parts.
  6. Brother MFC-490CW Scanning Glass Replacement, Replacing scanner glass: passo 6, immagine 1 di 3 Brother MFC-490CW Scanning Glass Replacement, Replacing scanner glass: passo 6, immagine 2 di 3 Brother MFC-490CW Scanning Glass Replacement, Replacing scanner glass: passo 6, immagine 3 di 3
    • Disconnect the glass from the tracks.
    • Remove old or broken glass.
    • Replace with adhesive tape along the bottom of the header and reassemble.
Conclusione
Altre 2 persone hanno completato questa guida.
UMass Dartmouth, Team 4-4, Miles Fall 2014 Membro di UMass Dartmouth, Team 4-4, Miles Fall 2014
UMASSD-MILES-F14S4G4
3 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 36
Ultimi 30 Giorni: 112
Tutti i Tempi: 4,558
