Salta al contenuto principale
Brother MFC-490CW Front Panel Replacement
Cosa ti serve
  1. Brother MFC-490CW Front Panel Replacement, Remove screws holding the front panel: passo 1, immagine 1 di 1
    • Use a Phillips #2 screwdriver to remove the three 12.1 mm screws holding the control panel in place.
  2. Brother MFC-490CW Front Panel Replacement, Unplug the panel from the rest of the printer: passo 2, immagine 1 di 3 Brother MFC-490CW Front Panel Replacement, Unplug the panel from the rest of the printer: passo 2, immagine 2 di 3 Brother MFC-490CW Front Panel Replacement, Unplug the panel from the rest of the printer: passo 2, immagine 3 di 3
    • Lift up the front panel from the device.
    • Gently lift up and disconnect the data cables that attach the panel to the printer.
Conclusione
To reassemble the front panel, follow these instructions in reverse order.
Altre 2 persone hanno completato questa guida.
Matt
Membro da: 10/30/14
64 Reputazione
2 Guide realizzate
UMass Dartmouth, Team 4-4, Miles Fall 2014 Membro di UMass Dartmouth, Team 4-4, Miles Fall 2014
UMASSD-MILES-F14S4G4
3 Membri
8 Guide realizzate
Un commento
Be sure the three plastic tabs on the bottom of the black front cover are inserted fully when you snap the cover back into place or else you will get a message saying the ink door is not closed.
Raymond Rinaldi - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,722
