Salta al contenuto principale
Brother MFC 7240 Toner Cartridge Replacement
Cosa ti serve
  1. Brother MFC 7240 Toner Cartridge Replacement, Toner Cartridge: passo 1, immagine 1 di 3 Brother MFC 7240 Toner Cartridge Replacement, Toner Cartridge: passo 1, immagine 2 di 3 Brother MFC 7240 Toner Cartridge Replacement, Toner Cartridge: passo 1, immagine 3 di 3
    • Ensure the printer is on a stable surface with enough room to access the ink cartridge compartment.
    • Turn off the printer by unplugging it from the outlet.
  2. Brother MFC 7240 Toner Cartridge Replacement: passo 2, immagine 1 di 2 Brother MFC 7240 Toner Cartridge Replacement: passo 2, immagine 2 di 2
    • Lift the printer cover which is located at the front of the printer to reveal the toner cartridge compartment.
  3. Brother MFC 7240 Toner Cartridge Replacement: passo 3, immagine 1 di 1
    • Locate the empty ink cartridge that needs replacement.
  4. Brother MFC 7240 Toner Cartridge Replacement: passo 4, immagine 1 di 3 Brother MFC 7240 Toner Cartridge Replacement: passo 4, immagine 2 di 3 Brother MFC 7240 Toner Cartridge Replacement: passo 4, immagine 3 di 3
    • Put your fingers under the slot underneath the toner cartridge and gently pull it out.
  5. Brother MFC 7240 Toner Cartridge Replacement: passo 5, immagine 1 di 3 Brother MFC 7240 Toner Cartridge Replacement: passo 5, immagine 2 di 3 Brother MFC 7240 Toner Cartridge Replacement: passo 5, immagine 3 di 3
    • Press down on the small green lever on the bottom left of the drum unit to release the cartridge.
    • You will need to push down the green lever and pull out the toner cartridge at the same time.
  6. Brother MFC 7240 Toner Cartridge Replacement: passo 6, immagine 1 di 3 Brother MFC 7240 Toner Cartridge Replacement: passo 6, immagine 2 di 3 Brother MFC 7240 Toner Cartridge Replacement: passo 6, immagine 3 di 3
    • Unpack the new toner cartridge.
  7. Brother MFC 7240 Toner Cartridge Replacement: passo 7, immagine 1 di 3 Brother MFC 7240 Toner Cartridge Replacement: passo 7, immagine 2 di 3 Brother MFC 7240 Toner Cartridge Replacement: passo 7, immagine 3 di 3
    • Remove the orange protective casing on the new toner cartridge.
    • Be careful with this step because the protective casing holds the ink so when removing it don't touch the ink roller underneath it or else you will get ink on your fingers.
  8. Brother MFC 7240 Toner Cartridge Replacement: passo 8, immagine 1 di 3 Brother MFC 7240 Toner Cartridge Replacement: passo 8, immagine 2 di 3 Brother MFC 7240 Toner Cartridge Replacement: passo 8, immagine 3 di 3
    • Slide the new cartridge into the drum unit slot until it clicks into place.
    • Ensure you can see the Brother logo on top.
  9. Brother MFC 7240 Toner Cartridge Replacement: passo 9, immagine 1 di 3 Brother MFC 7240 Toner Cartridge Replacement: passo 9, immagine 2 di 3 Brother MFC 7240 Toner Cartridge Replacement: passo 9, immagine 3 di 3
    • Place the cartridge and drum unit into the printer and close the cover.
  10. Brother MFC 7240 Toner Cartridge Replacement: passo 10, immagine 1 di 3 Brother MFC 7240 Toner Cartridge Replacement: passo 10, immagine 2 di 3 Brother MFC 7240 Toner Cartridge Replacement: passo 10, immagine 3 di 3
    • Turn on the printer by plugging it back in.
    • Make sure you don’t get the low toner cartridge message.
Linea Traguardo
Gurnoor Loee
Membro da: 01/15/24
181 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 17
Tutti i Tempi: 218
