Salta al contenuto principale
Brother IntelliFax-2840 Control Panel Replacement
Cosa ti serve
  1. Brother IntelliFax-2840 Control Panel Replacement, Automatic Document Feeder: passo 1, immagine 1 di 1
    • Remove the two 15 mm Phillips #1 screws securing the ADF at the rear of the fax machine.
  2. Brother IntelliFax-2840 Control Panel Replacement: passo 2, immagine 1 di 2 Brother IntelliFax-2840 Control Panel Replacement: passo 2, immagine 2 di 2
    • Gently pull the ADF up and away from the machine.
  3. Brother IntelliFax-2840 Control Panel Replacement, Control Panel: passo 3, immagine 1 di 2 Brother IntelliFax-2840 Control Panel Replacement, Control Panel: passo 3, immagine 2 di 2
    • Gently lift up the control panel.
  4. Brother IntelliFax-2840 Control Panel Replacement: passo 4, immagine 1 di 3 Brother IntelliFax-2840 Control Panel Replacement: passo 4, immagine 2 di 3 Brother IntelliFax-2840 Control Panel Replacement: passo 4, immagine 3 di 3
    • Use a finger or prying tool to gently pop off the right side control arm (furthest from the handset).
    • Repeat for the left side control arm.
    • You can make this task easier by taking the handset out of the cradle and setting it aside.
  5. Brother IntelliFax-2840 Control Panel Replacement: passo 5, immagine 1 di 2 Brother IntelliFax-2840 Control Panel Replacement: passo 5, immagine 2 di 2
    • Do not attempt to completely remove the control panel yet, as it is still connected by a cable.
    • Lifting from the front edge, gently flip up the control panel.
  6. Brother IntelliFax-2840 Control Panel Replacement: passo 6, immagine 1 di 1
    • While supporting the control panel with one hand, remove the three 12.2 mm Phillips #1 screws securing the rear control panel cover.
  7. Brother IntelliFax-2840 Control Panel Replacement: passo 7, immagine 1 di 1
    • While still supporting the control panel, use your fingers or a spudger to gently free the two plastic clips securing the rear control panel cover.
    • Slide the rear control panel cover down slightly to free it from the three clips along the upper edge.
  8. Brother IntelliFax-2840 Control Panel Replacement: passo 8, immagine 1 di 2 Brother IntelliFax-2840 Control Panel Replacement: passo 8, immagine 2 di 2
    • Separate the rear control panel cover from the control panel.
  9. Brother IntelliFax-2840 Control Panel Replacement: passo 9, immagine 1 di 2 Brother IntelliFax-2840 Control Panel Replacement: passo 9, immagine 2 di 2
    • Gently pull the control panel cable straight out from its connector.
    • The control panel should now come free.
Conclusione
Geoff Wacker
Membro da: 09/30/13
92.048 Reputazione
89 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 4,445
