Salta al contenuto principale
Brother HL-5240 Drum Unit and Toner Cartridge Replacement
  1. Brother HL-5240 Drum Unit and Toner Cartridge Replacement, Drum Unit and Toner Cartridge: passo 1, immagine 1 di 1
    • Press the front cover release button.
    • Keep the button pressed and pull the cover toward yourself.
  2. Brother HL-5240 Drum Unit and Toner Cartridge Replacement: passo 2, immagine 1 di 3 Brother HL-5240 Drum Unit and Toner Cartridge Replacement: passo 2, immagine 2 di 3 Brother HL-5240 Drum Unit and Toner Cartridge Replacement: passo 2, immagine 3 di 3
    • With the front cover in the downward position, the drum & toner unit will be visible.
    • Grab the black-and-yellow handle on the unit. Lift unit up and pull it out of the printer.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 4-14, Forte Winter 2010 Membro di Cal Poly, Team 4-14, Forte Winter 2010
CPSU-FORTE-W10S4G14
5 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 15
Tutti i Tempi: 8,735
