Salta al contenuto principale
Brother DCP-L2550DW Toner Cartridge Replacement
Cosa ti serve
  1. Brother DCP-L2550DW Toner Cartridge Replacement, Toner Cartridge: passo 1, immagine 1 di 2 Brother DCP-L2550DW Toner Cartridge Replacement, Toner Cartridge: passo 1, immagine 2 di 2
    • Unplug your printer from the outlet. Identify your printer and the toner cartridge required.
    • The printer recommends only two cartridges, TN-730 and TN-760.
  2. Brother DCP-L2550DW Toner Cartridge Replacement: passo 2, immagine 1 di 3 Brother DCP-L2550DW Toner Cartridge Replacement: passo 2, immagine 2 di 3 Brother DCP-L2550DW Toner Cartridge Replacement: passo 2, immagine 3 di 3
    • Pull on the tab to open the front plate of your printer.
  3. Brother DCP-L2550DW Toner Cartridge Replacement: passo 3, immagine 1 di 3 Brother DCP-L2550DW Toner Cartridge Replacement: passo 3, immagine 2 di 3 Brother DCP-L2550DW Toner Cartridge Replacement: passo 3, immagine 3 di 3
    • Pull on the green handle to remove the drum unit of your printer.
  4. Brother DCP-L2550DW Toner Cartridge Replacement: passo 4, immagine 1 di 3 Brother DCP-L2550DW Toner Cartridge Replacement: passo 4, immagine 2 di 3 Brother DCP-L2550DW Toner Cartridge Replacement: passo 4, immagine 3 di 3
    • Place the drum unit on a clean flat surface.
    • Press down on the green button at the bottom left corner of the drum unit to unlock the toner cartridge.
    • Remove the toner cartridge from the drum unit.
  5. Brother DCP-L2550DW Toner Cartridge Replacement: passo 5, immagine 1 di 3 Brother DCP-L2550DW Toner Cartridge Replacement: passo 5, immagine 2 di 3 Brother DCP-L2550DW Toner Cartridge Replacement: passo 5, immagine 3 di 3
    • Insert the new toner cartridge into the drum unit by placing it on top of the drum unit and pressing it down, ensuring it is in the locked position.
    • Do not touch the ink roll of the cartridge. It can compromise the quality of the ink.
  6. Brother DCP-L2550DW Toner Cartridge Replacement: passo 6, immagine 1 di 3 Brother DCP-L2550DW Toner Cartridge Replacement: passo 6, immagine 2 di 3 Brother DCP-L2550DW Toner Cartridge Replacement: passo 6, immagine 3 di 3
    • Insert the drum unit back into the printer by placing it at the edge of the opening and sliding it inside until it locks in place.
  7. Brother DCP-L2550DW Toner Cartridge Replacement: passo 7, immagine 1 di 3 Brother DCP-L2550DW Toner Cartridge Replacement: passo 7, immagine 2 di 3 Brother DCP-L2550DW Toner Cartridge Replacement: passo 7, immagine 3 di 3
    • Close the front plate and ensure it is in the locked position.
  8. Brother DCP-L2550DW Toner Cartridge Replacement: passo 8, immagine 1 di 1
    • Replacement completed. Plug the printer back in the outlet and test it out. You can now use your printer.
Conclusione
Syed Momin Raza
Membro da: 01/09/24
157 Reputazione
1 Guida realizzata
Un commento
Hi , I’m facing unable to print double sided issue. It able to print on 1 page, but when the paper roll back and ready to print on the other page, it stuck. Could you help me on this?
Shininimi Here - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 58
Tutti i Tempi: 311
