Salta al contenuto principale
Brother CE8080 Bobbin Replacement
Cosa ti serve
  1. Brother CE8080 Bobbin Replacement, Bobbin: passo 1, immagine 1 di 1
    • Make sure that the presser foot (the part that holds fabric in place) is in the raised position before removing the bobbin cover.
    • Lift the bobbin cover case found beneath the needle.
  2. Brother CE8080 Bobbin Replacement: passo 2, immagine 1 di 1
    • Pull the defective bobbin out of the bobbin case and dispose of it properly.
    • Empty the thread from the defective bobbin before disposing of it so you can use the excess thread.
  3. Brother CE8080 Bobbin Replacement: passo 3, immagine 1 di 2 Brother CE8080 Bobbin Replacement: passo 3, immagine 2 di 2
    • Take the new bobbin and place it inside the bobbin case.
    • Pull at least two inches of thread from the end of the bobbin so you're able to access it and it doesn't get tangled.
  4. Brother CE8080 Bobbin Replacement: passo 4, immagine 1 di 1
    • Pull the thread at the end of the bobbin that's sticking out from the base of the machine.
  5. Brother CE8080 Bobbin Replacement: passo 5, immagine 1 di 3 Brother CE8080 Bobbin Replacement: passo 5, immagine 2 di 3 Brother CE8080 Bobbin Replacement: passo 5, immagine 3 di 3
    • Insert the thread carefully to the tension-adjusting spring of the bobbin case.
    • The Brother CE8080 has a built-in arrow guide that shows you where to insert the thread.
  6. Brother CE8080 Bobbin Replacement: passo 6, immagine 1 di 1
    • Cut off excess thread using fabric scissors.
    • Make sure to cut the end of the thread at a slanted angle to prevent thread breakage.
  7. Brother CE8080 Bobbin Replacement: passo 7, immagine 1 di 1
    • Place the bobbin cover back in its original position on the sewing machine.
    • Make sure it "clicks" when placing the bobbin cover back. The click sound ensures that the cover is locked.
Conclusione
LOU ERIKA U MUEGA
Membro da: 07/03/22
145 Reputazione
1 Guida realizzata
2 Commenti
I found your guide straightforward to read and understand, and it is typically adequate. In my opinion, the presence of clear images and the marker you used in the first picture will help and enable readers to repair their sewing machine easily. Well done!
Rami Yamout - Replica
Excellent illustration!!!
KO SAMUEL TAK SHUN - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 34
Tutti i Tempi: 913
