Salta al contenuto principale
Broan-Nutone NU230BL Filter and Light Replacement
Cosa ti serve
  1. Broan-Nutone NU230BL Filter and Light Replacement, Filter and Light: passo 1, immagine 1 di 1
    • Make sure the fan switch is centered, and the light switch is set to "off" to avoid any injuries.
  2. Broan-Nutone NU230BL Filter and Light Replacement: passo 2, immagine 1 di 1
    • Squeeze both ends of the bulb cover to pop it out of the slots.
  3. Broan-Nutone NU230BL Filter and Light Replacement: passo 3, immagine 1 di 2 Broan-Nutone NU230BL Filter and Light Replacement: passo 3, immagine 2 di 2
    • Make sure the lightbulb is cool before handling to avoid burns.
    • Unscrew and remove the lightbulb by turning it counterclockwise.
  4. Broan-Nutone NU230BL Filter and Light Replacement: passo 4, immagine 1 di 3 Broan-Nutone NU230BL Filter and Light Replacement: passo 4, immagine 2 di 3 Broan-Nutone NU230BL Filter and Light Replacement: passo 4, immagine 3 di 3
    • Twist the latch above the filter clockwise.
    • Slide the filter out by gently pulling it.
  5. Broan-Nutone NU230BL Filter and Light Replacement: passo 5, immagine 1 di 3 Broan-Nutone NU230BL Filter and Light Replacement: passo 5, immagine 2 di 3 Broan-Nutone NU230BL Filter and Light Replacement: passo 5, immagine 3 di 3
    • Insert the new filter.
    • Rotate the retaining latch counterclockwise to secure the filter.
  6. Broan-Nutone NU230BL Filter and Light Replacement: passo 6, immagine 1 di 2 Broan-Nutone NU230BL Filter and Light Replacement: passo 6, immagine 2 di 2
    • Install the new lightbulb and turn it clockwise.
  7. Broan-Nutone NU230BL Filter and Light Replacement: passo 7, immagine 1 di 2 Broan-Nutone NU230BL Filter and Light Replacement: passo 7, immagine 2 di 2
    • Reinsert the lightbulb cover by pressing both sides and fitting the cover's tabs into the slots.
Conclusione
Your range hood is good-to-go!
Mahdi M
Membro da: 01/17/22
169 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 35
Tutti i Tempi: 736
