Salta al contenuto principale
BrightSign 4K Battery Charging Port Replacement
Cosa ti serve
  1. BrightSign 4K Battery Charging Port Replacement, Outer Shell: passo 1, immagine 1 di 3 BrightSign 4K Battery Charging Port Replacement, Outer Shell: passo 1, immagine 2 di 3 BrightSign 4K Battery Charging Port Replacement, Outer Shell: passo 1, immagine 3 di 3
    • Remove three 8mm screws from the left side of the device.
    • Remove four 8mm screws from the right side of the device.
  2. BrightSign 4K Battery Charging Port Replacement: passo 2, immagine 1 di 3 BrightSign 4K Battery Charging Port Replacement: passo 2, immagine 2 di 3 BrightSign 4K Battery Charging Port Replacement: passo 2, immagine 3 di 3
    • Apply pressure on the SD card to pop it out of the port.
    • Remove the card by pulling it out.
  3. BrightSign 4K Battery Charging Port Replacement: passo 3, immagine 1 di 3 BrightSign 4K Battery Charging Port Replacement: passo 3, immagine 2 di 3 BrightSign 4K Battery Charging Port Replacement: passo 3, immagine 3 di 3
    • Press down on the top cover of the device and slid it towards you until you see a slight gap created.
    • Lift the top cover off.
  4. BrightSign 4K Battery Charging Port Replacement: passo 4, immagine 1 di 3 BrightSign 4K Battery Charging Port Replacement: passo 4, immagine 2 di 3 BrightSign 4K Battery Charging Port Replacement: passo 4, immagine 3 di 3
    • Slide the body case back away from the bottom.
    • Pull up the body case to remove it from the bottom.
  5. BrightSign 4K Battery Charging Port Replacement, Motherboard Removal: passo 5, immagine 1 di 2 BrightSign 4K Battery Charging Port Replacement, Motherboard Removal: passo 5, immagine 2 di 2
    • Remove the four 8mm screws at each corner of the motherboard with a JIS #0 screwdriver.
  6. BrightSign 4K Battery Charging Port Replacement: passo 6, immagine 1 di 2 BrightSign 4K Battery Charging Port Replacement: passo 6, immagine 2 di 2
    • Lift the motherboard out of the casing.
  7. BrightSign 4K Battery Charging Port Replacement, Battery Charging Port: passo 7, immagine 1 di 3 BrightSign 4K Battery Charging Port Replacement, Battery Charging Port: passo 7, immagine 2 di 3 BrightSign 4K Battery Charging Port Replacement, Battery Charging Port: passo 7, immagine 3 di 3
    • Flip the motherboard over so the heatsink is facing down.
    • Desolder the four solder joints and remove the melted solder with the pump.
  8. BrightSign 4K Battery Charging Port Replacement: passo 8, immagine 1 di 3 BrightSign 4K Battery Charging Port Replacement: passo 8, immagine 2 di 3 BrightSign 4K Battery Charging Port Replacement: passo 8, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Desoldering Pump
    $3.99
    Compra
    • Apply the desoldering pump to remove the melted part from the motherboard (press the button to release it).
    • Using the tweezers apply pressure to the spade head clip shown.
    • Remove the charging port by pulling the piece off.
Conclusione
Nhi Pham
Membro da: 02/15/18
169 Reputazione
2 Guide realizzate
USF Tampa, Team S17-G6, Boczar Spring 2018 Membro di USF Tampa, Team S17-G6, Boczar Spring 2018
USFT-BOCZAR-S18S17G6
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 299
