Salta al contenuto principale
Briggs and Stratton 675 Series Repair Air Filter Replacement
Cosa ti serve
  1. Briggs and Stratton 675 Series Repair Air Filter Replacement, Air Filter: passo 1, immagine 1 di 1
    • Make sure the the engine is off and the spark plug wire is removed and away from the spark plug before beginning.
    • Use a Flathead #4 screw driver to remove the 40mm screw that holds the air filter case in place.
  2. Briggs and Stratton 675 Series Repair Air Filter Replacement: passo 2, immagine 1 di 1
    • Use your hands to pull the air filter case out of the hinge at the bottom.
  3. Briggs and Stratton 675 Series Repair Air Filter Replacement: passo 3, immagine 1 di 1
    • Simply remove the air filter with your hands.
Conclusione
Altre 6 persone hanno completato questa guida.
Cal Poly, Team 6-31, Amido Winter 2015 Membro di Cal Poly, Team 6-31, Amido Winter 2015
CPSU-AMIDO-W15S6G31
4 Membri
14 Guide realizzate
2 Commenti
Good information, although it didn't resolve my issue. Thanks for sharing
all2thegoodpromo - Replica
This is a power wash motor water will not come out
hdoggett Doggett - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 62
Ultimi 30 Giorni: 251
Tutti i Tempi: 19,483
