Salta al contenuto principale
Briefcase Strap Holder Replacement
Cosa ti serve
  1. Briefcase Strap Holder Replacement, Strap Holder: passo 1, immagine 1 di 1
    • Cut the whole old strap holder from the bag.
    • If the strap holder breaks in other parts, cut it all out.
  2. Briefcase Strap Holder Replacement: passo 2, immagine 1 di 2 Briefcase Strap Holder Replacement: passo 2, immagine 2 di 2
    • Draw a longer shape of the strap holder with a pencil on another piece of fabric.
    • Both extensions should be the same length, at least 1/4 to 1/2inch long.
  3. Briefcase Strap Holder Replacement: passo 3, immagine 1 di 1
    • Cut the piece of fabric.
  4. Briefcase Strap Holder Replacement: passo 4, immagine 1 di 2 Briefcase Strap Holder Replacement: passo 4, immagine 2 di 2
    • Add glue in the center of the new piece of fabric.
    • Glue the strap holder on in the center and leave the same length on both sides.
    • You can also use a glue gun.
  5. Briefcase Strap Holder Replacement: passo 5, immagine 1 di 2 Briefcase Strap Holder Replacement: passo 5, immagine 2 di 2
    • Use a sewing machine to sew the strap holder with the glued piece of fabric in the center.
    • If you have good sewing skills, you can sew on both sides.
  6. Briefcase Strap Holder Replacement: passo 6, immagine 1 di 2 Briefcase Strap Holder Replacement: passo 6, immagine 2 di 2
    • Place the metal strap holder between the leather strap holder and fold it.
    • Use the sewing machine to sew the tips of the fabric that was glued on the leather strap holder.
    • If your metal strap holder is openable, sew without the metal strap holder.
  7. Briefcase Strap Holder Replacement: passo 7, immagine 1 di 2 Briefcase Strap Holder Replacement: passo 7, immagine 2 di 2
    • Add more glue between the fabric and the leather strap holder to strengthen it and hold it while it dries.
  8. Briefcase Strap Holder Replacement: passo 8, immagine 1 di 1
    • Trim the area where the strap holder is placed.
  9. Briefcase Strap Holder Replacement: passo 9, immagine 1 di 3 Briefcase Strap Holder Replacement: passo 9, immagine 2 di 3 Briefcase Strap Holder Replacement: passo 9, immagine 3 di 3
    • Add glue with a glue gun to the area where the strap holder is placed.
    • Place the strap holder in the strap holder area of the bag and hold it while it dries.
    • It is recommended to sew the strap holder fabric to the area where it will be placed.
Linea Traguardo
Hao Yi Michelle Lu
Membro da: 11/05/24
169 Reputazione
1 Guida realizzata
UC Davis, Team 1-8, Vidal-Chiesa Fall 2024 Membro di UC Davis, Team 1-8, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S1G8
2 Membri
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 32
Tutti i Tempi: 291
