Introduzione
You will be removing the safety locking arm. Make sure the juicer is off and unplugged before disassembly. If you have trouble starting the juicer, keep in mind that the safety locking arm has to be properly engaged in order for the juicer to work.
Cosa ti serve
Place the juicer on a flat surface. Make sure the juicer is unplugged and in the "off" position. For the following steps, the pulp basket is on the left.
Place one hand on either side of the safety locking arm.
Disengage the locking mechanism by pulling down on the lever with even pressure. The lever should be free to move up or down once it has been properly disengaged.
