Salta al contenuto principale
Breville BKC600XL Water Valve Replacement
Cosa ti serve
  1. Breville BKC600XL Water Valve Replacement, "Bottom" Black Shell Piece: passo 1, immagine 1 di 3 Breville BKC600XL Water Valve Replacement, "Bottom" Black Shell Piece: passo 1, immagine 2 di 3 Breville BKC600XL Water Valve Replacement, "Bottom" Black Shell Piece: passo 1, immagine 3 di 3
    • Remove the two 12mm black Phillips screws using a Phillips #0 screwdriver.
    • Reminder for reassembly; This bottom piece is first to be screwed back on.
  2. Breville BKC600XL Water Valve Replacement, "Top" Black Shell Piece: passo 2, immagine 1 di 1
    • Remove the two 12mm Phillips screws using a Phillips #0 screwdriver.
  3. Breville BKC600XL Water Valve Replacement, Silver Casing: passo 3, immagine 1 di 3 Breville BKC600XL Water Valve Replacement, Silver Casing: passo 3, immagine 2 di 3 Breville BKC600XL Water Valve Replacement, Silver Casing: passo 3, immagine 3 di 3
    • Remove the grey plastic casing.
    • Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver.
  4. Breville BKC600XL Water Valve Replacement, Water Valve: passo 4, immagine 1 di 1
    • Cut the band connecting the hose to the water valve.
    • Remove the water valve.
    • Reminder for reassembly; You will need a new band to tie the hose back to the water valve.
Conclusione
Antonio
Membro da: 09/26/12
120 Reputazione
6 Guide realizzate
Cal Poly, Team 1-3, Propen Fall 2012 Membro di Cal Poly, Team 1-3, Propen Fall 2012
CPSU-PROPEN-F12S1G3
4 Membri
6 Guide realizzate
2 Commenti
Where can I buy a new water valve assembly? Are they custom to the device or generally available ? Thanks!
Betsy Goodrich - Replica
Hi same question :)
Aiqui2@hotmail.com - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 5,876
