Salta al contenuto principale
Brentwood TS-292B Toasting Lever Replacement
Cosa ti serve
  1. Brentwood TS-292B Toasting Lever Replacement, Toasting Lever: passo 1, immagine 1 di 2 Brentwood TS-292B Toasting Lever Replacement, Toasting Lever: passo 1, immagine 2 di 2
    • Use a Phillips #2 screwdriver to remove all of the 6mm screws from the bottom of the toaster.
  2. Brentwood TS-292B Toasting Lever Replacement: passo 2, immagine 1 di 3 Brentwood TS-292B Toasting Lever Replacement: passo 2, immagine 2 di 3 Brentwood TS-292B Toasting Lever Replacement: passo 2, immagine 3 di 3
    • Push in the small tab located to the left, and pull the lever tab away from the toaster with force.
    • Remove the toaster cover carefully.
  3. Brentwood TS-292B Toasting Lever Replacement: passo 3, immagine 1 di 1
    • Detach the bundled cable connector by carefully pulling it away from the circuit board.
  4. Brentwood TS-292B Toasting Lever Replacement: passo 4, immagine 1 di 2 Brentwood TS-292B Toasting Lever Replacement: passo 4, immagine 2 di 2
    • Push the tabs in and lift the top of the toaster off.
  5. Brentwood TS-292B Toasting Lever Replacement: passo 5, immagine 1 di 3 Brentwood TS-292B Toasting Lever Replacement: passo 5, immagine 2 di 3 Brentwood TS-292B Toasting Lever Replacement: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Lift up the tab that is located at the front of the toasting lever.
    • Use tweezers to carefully lift up the metal bar.
    • Remove the springs and replace them with new ones.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 614
