Salta al contenuto principale
Brentwood TS-292B Power Cable Replacement
Cosa ti serve
  1. Brentwood TS-292B Power Cable Replacement, Power Cable: passo 1, immagine 1 di 1
    • Remove the five 6mm screws on the bottom of the toaster with a Phillips #2 screw driver.
  2. Brentwood TS-292B Power Cable Replacement: passo 2, immagine 1 di 1
    • To remove the toasting lever, pull the lever away from the toaster.
  3. Brentwood TS-292B Power Cable Replacement: passo 3, immagine 1 di 1
    • Unplug the wire connecting the casing to the circuit board to fully remove the toaster casing.
  4. Brentwood TS-292B Power Cable Replacement: passo 4, immagine 1 di 1
    • Unscrew the wire bracket with a Phillips #2 screw driver.
  5. Brentwood TS-292B Power Cable Replacement: passo 5, immagine 1 di 1
    • Pull back on the black tab that is holding the circuit board in place.
    • While pulling the tab back, lift up on the circuit board.
  6. Brentwood TS-292B Power Cable Replacement: passo 6, immagine 1 di 1
    • Desolder the power wire connections on the circuit board.
    • Desolder in a well ventilated area.
    • The tip of soldering iron is hot handle with caution.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 171
